Question about RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh
The Blackberry 8320 phone does not turn ON. It displays a battery with a slash across it. The red led turns on momentarily. The battery is in great shape, it works on other Balckberrys, measures 3.8v.
  • 1 more comment
  • l2theb20 Mar 15, 2009
  • Anonymous Mar 27, 2009
    I am facing the same problem. My 8320 suddenly did not switch ON .. the red light flashes once when kept on charging. However the battery is perfectly fine. Please help.
  • spydrgt Apr 02, 2009
    My blackberry curve 8320 just shut off out of no where and when i turned it on, it had a battery with a red slash. i was told to get a new battery but im a cheap guy and plus i didnt have time to go get one because of work. so i left it alone to charge and its been 2 days since i've touched it and finally it works!
Even m going through the same problem and m not geting what to do please guys help as fast as possible
Posted on Oct 22, 2010
My blackberry displays a battery with red slash across icon. I have removed and put the battery and each time the red LED light comes up and the same image is displayed. No button works either.Please help...
hi your blackberry is not recognising the fact that you have installed your battery this is a softrware problem that needs to be resolved by your blackberry agent.hope this helps.
Aug 29, 2010 | Computers & Internet
Att blackberry 8320 will not power up. no
hello,
try to charge the battery for a while, then try to turn it on.
goodluck
Feb 04, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
Every time i turn on my blackberry 8320 it says battery drained.
It is the main board. If you have phone insurance through your carrier they should be able to replace it. Otherwise there is not much you can do aside from purchase of a new phone.
Jan 12, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
I have a blackberry curve 8320 battery is fully charged and it wont turn on _ i tried another battery and it still wont turn on
I would like to suggest you to visit the outlet from where you have purchased the handheld to service the handheld.
Hope I have helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 06, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry curve 8320 phone does not turn on but red let goes on then turns off. not the battery
you need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work...it has for every phone i fix that just have a red led blinking...also if the DM does not see your PIN, remove the battery from the phone then connect it again you should see BB PIN:UNKNOWN just click next and you should be good to go.
Oct 09, 2009 | RIM Blackberry Curve 8300
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. The icon stays on with the backlight until the battery dies, A new battery was tried and problem...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My blackberry 8320 wont turn on no blinking nothing not even
Try a new battery or have your battery charged on another 8300 series phone, then install it in your phone. Typically, if the battery is below a certain voltage ("dead") the charging circuit does not become active, therefore not enough voltage to turn on your 8320. Also if it has been dropped or got water damage, these can also cause that problem.
Mar 06, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Screen shows a battery with a red slash
This could mean a few things. Here are the different ways to try to fix it:
1. Charge your battery for at least an hour, preferably overnight. If that doesn't get rid of the red slash, continue down this list...
2. Try a fully-charged battery from another phone. Either borrow a battery from someone or go to a local store to try one. If the red slash goes away, your battery is defective. If you have had your Blackberry for less than a year, your service provider should replace it at no cost. The number for warranty service is: 1-800-801-1101.
3. Try your battery in another phone. Again, if your battery does not work in the other phone, your battery is defective. If your battery does work in the other phone, you have a software issue.
You need to download the latest version for your device. You can get that either from your service provider's web site or from Blackberry (www.blackberry.com).
Save the folder to your desktop, double click it to install it your computer - be patient - it can take a while.
After you have downloaded the software to your desktop, connect your blackberry. Go into the Desktop Manager on your computer and use the program called Application Loader to install the new software on your Blackberry. Make sure that, when you see the "Advanced" box, you choose that option. Make sure you check both boxes to remove all current installed software.
4. Finally, if reloading the software does not work, likely your Blackberry is defective. You should call your service provider and ask that it be replaced (Note: call them even if you are out of the warranty period; if you are a good customer, they will often replace your phone anyway).
Hope that helps.
Jan 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry wont turn on just shows red line through battery
just put a piece of paper on the top of the battery (the part where u push it down) it shows the battery with a red line slashed across because its too loose...
it worked for me!
Nov 24, 2008 | RIM BlackBerry Pearl Smartphone
RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
1,058 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
