Http://www.pcmag.com/encyclopedia/term/38515/beep-codes
here are the explenation of beep-codes i hope this page can help you.
SOURCE: ethernet controller driver
You can download drivers from;
http://www.emachine.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W4685
Please report back to the thread the results of your work.
Regards;
Hassan
SOURCE: I have Emachine 2002 model W4682 problem with all
You should have gotton a cd with the orginal drivers with you machine. They may also be hidden on you machine.
Remember that the maker of your machine is gateway. I suggest calling them if you have no luck with the emachine division. The company called Acer is the parent company of all of them. That should help. Emachine is not the bst cmpany outthere when it comes to customer service. What is not working correct on your machne??
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
SOURCE: When using the restore discs on my emachine w4682, restore freeze
insert the windows disc and restart the system,
then repair the system using repair option.
SOURCE: I AM TROUBLESHOOTING AN EMACHINE MODEL W3410 AMD
Almost always indicative of a RAM memory problem. Troubleshoot by removing 1 stick of memory and rebooting. Switch sticks to determine if either stick of memory is bad or a bad bank on the motherboard.
