Question about netTALK DUO II Voice Over Internet Protocol Telephone Device with 3 Mo
Nettalk problems last 7days i can call but my incoming call problems.nobody can not call me.what can i do?
What happened to netTalk? HONE WENT OUT AND NO WEBSITE ANYMORE.
Website is there
http://www.nettalk.ca
That said, they do have problems from September 22, 2015
http://www.themiddlemarket.com/news/restructurings/troubled-telecom-business-nettalk-adds-lawsuit-to-list-of-problems-258184-1.html
Nov 20, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
My Duo has dial tone, I can dial out, and it works fine. But when anyone calls me they immediately get an automated message to the effect "the number you dialed is not a working number, please hang-up and...
This is a problem with the your VOIP carrier failing to translate and switch incoming calls to your device. Contact them and describe the problem and they should be able to fix it fairly quickly.
Mar 06, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
I got a nettalk duo, it work perfectly but since last friday, i get a ring tone, but i cant dial out, when ppl called me says my number is inactive
Try resetting the box by unplugging the cord next to the green (sometimes red) light it briefly and then return the plug into the box.
Oct 12, 2014 | netTALK DUO2 VOIP Telephone Service
Problems with nettalk
Go to: https://www.nettalkconnect.com/login
Login to your account, click the "Click Chat" under "Logout" (near right top of page) to converse with a CSR to find out the answers to your question.
Jul 22, 2014 | netTALK DUO WI-FI VoIP Gateway
I have received an email from nettalk regarding renewal of fees. The amount concerned has not been mentioned . What is the amount. Also we have been having avery bad time trying to fix the nettalk phone....
first , the amount is missing and that points immediately to a scam as the company would put the amount in the account
contact the nettalk service provider by phone on the number on their web page " contact us " section
do not use the link if provided in the e-mail as that is the door to everything for scammers
Apr 29, 2017 | netTALK
HOW DO I DISCONNECT MY SERVICE WITH NETTALK
You have to contact Nettalk and advise them you want to terminate your account with them.
Mar 15, 2013 | Computers & Internet
My nettalk duo's red light is constantly on .its not working. how can i fix it.
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
Feb 11, 2012 | NetGear Computers & Internet
I just setup Nettalk Duo and can send and receive calls. But the Answering machine will not work. I have it set for 4 rings and Nettalk voicemail is set for 5 rings. Any suggestions, please help.
Login to your Nettalk account and click on the voicemail tab on the left. Make sure to turn off your voicemail settings for your Nettalk device and save settings. Your answering machine should now pick up after 4 rings.
Mar 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Have an SBG6580 and purchased a NETTALK DUO (VOIP). Which is trying to connect but can't. Tech support at Nettalk tried to change some settings but it looks like modem is still blocking the port. ...
The only way I got the NETTALK DUO to work keeping my SBG6580 is to use it in cascading mode with my old Linksys router. When I plugged the DUO into the Linksys it worked great.
Nov 14, 2010 | Motorola Computers & Internet
Need help!! nobody can`t hear me..
I had the very same problem, i solved it by opening the device and while checking the wires one of them was cut, so i changed and it is working good now.
Sep 24, 2008 | Motorola Mobility HS850 Consumer Headset
netTALK DUO II Voice Over Internet Protocol Telephone Device with 3 Mo Logo
169 people viewed this question
Top netTALK Lands Phones Experts
Steve Centanne
Steve Centanne
Level 1 Expert
Beth
Beth
shuyumeng
shuyumeng
Are you a netTALK Lands Phone Expert? Answer questions, earn points and help others
