Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Model # WD-62525 lost picture
My TV went black with green streaks and then it went completely black. The lamp light came on changed it and there was no change. Told it could be the capacitors and would have to go back to Mitsubishi to be fixed. Is this true or could a layman change it? Where can I get these parts?
  • 40 Answers
Really hard fix. but its like 350 to send it off to the repair center in cali.
Posted on Mar 13, 2009
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi: The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
Sep 26, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
