Question about Canon PIXMA Office Equipment & Supplies
Advice on Black Ink Failure
My black ink has suddenly completely stopped jetting. I've tried cleaning, but that hasn't helped, also changed the cartridge. At the moment I'm thinking of replacing the print head, but at 60GBp, I would like to be sure that that is the problem. Is there any way of confirming that the print head is faulty or should I just replace it? Many thanks, Ernie
  • Canon Master
  • 2,385 Answers
Yeah it is suggested that you may go for head replacment
Posted on Apr 24, 2013
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
  • 49 Answers
SOURCE: Faulty Ink Cartridge?
You can try this, but maybe a new print head is needed.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
wayneard
  • 1901 Answers
SOURCE: Black Ink won't print
Try cleaning the printheads:
On the control panel press Setup>Select Tools>Select Clean Printhead
If that doesn't work, try manual cleaning the printhead contacts. This begins on page 147 of the User Guide.
L7580 User Guide
Posted on Nov 19, 2008
SOURCE: won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Posted on Apr 25, 2009
  • 1810 Answers
SOURCE: After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Posted on Aug 03, 2009
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
Will only print yellow, black and photo black-- red cartridge shows ink in window and I just refilled blue-- cartridge was only out of printer a few hours. I've cleaned the print head a number of...
There are a few things here that will do this. One is the cartridge is a smart cartridge and unless you reset the chip it either won't print or shows low. If you filled it before then this shouldn't be it. If you have refilled the cart more than a few times they sometimes just stop. This is either the ink has jelled inside or the little feeder sponge is dried out. If you changed ink brands sometimes the ink reacts with the old stuff and jells.The other is the jet or any feeder tubes are plugged with dried ink. Usually happens if you haven't printed for a while. You can try running the cleaning cycle and it will take quite a few of these sometimes before it starts working.
There are a few more tricks for cleaning such as using white vinegar to dissolve dried ink but that's a bit of the messy side sometimes. Usually we have just had to buy a replacement cartridge after spending the time on this. We eventually just got rig of our ink jets and got some of the cheaper color laser printers. Wish we had done that sooner.
Sep 01, 2011 | HP Photosmart D7560 InkJet Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
Nukote Black Ink Jet Replaces HP21
clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
Jan 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
24 people viewed this question
old marine
old marine
