Question about Canon Office Equipment & Supplies
Canon mp 550
The black ink cartridge has suddenly stopped jetting completely without any warning like poor print quality. Before I splash out 60GBp on a new print head, how likely is it that something else is faulty?
  • Canon Master
  • 2,385 Answers
If cartridge is new new then go for head
Posted on Apr 24, 2013
danasaur
  • 77 Answers
SOURCE: Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Posted on Dec 12, 2007
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
SOURCE: My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Posted on Jun 14, 2009
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
  • 415 Answers
SOURCE: I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Posted on Feb 11, 2010
Advice on Black Ink Failure
yeah it is suggested that you may go for head replacment
Apr 23, 2013 | Canon PIXMA Office Equipment & Supplies
The printer stopped printting and display e07
The ink cartridge is not in the correct position. Try to reinstall it.
Nov 01, 2012 | Canon Black Pixma Mp 280 High Quality...
Canon ip2700 after refill of Black cartridge ink status still shows 'low' and print is very poor - breaks, incomplete - as ink running out. How to reset ink level, or to disable warning, and to get print...
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 20, 2011 | Canon iP2700 Inkjet Photo Printer
My canon printer mp 630 takes two black ink cartridges. one regular size and one larger The smaller one is very low.on ink. Is that the reason the printed picture is of poor quality having a lot of...
It need not be the case due to a low ink level in the smaller cartridge but if there is a problem with the printing head this can be a suspect. So try and use a good head cleaning then reset the printer driver software after un-installing and reinstalling before the printer is connected once again.
If this wont solve the ink cartridge must be changed to have a last try before the head is doubted. .
Mar 21, 2011 | Canon Office Equipment & Supplies
My Brother LC61 Series printer does not print - printer is less than 1-yr. I purchased new ink cartridge a couple days ago, however, all of a sudden, the printer will not print.
1st question that should be asked, is was it a genuine Brother approved cartridge with the right value of filtered ink?
If not then the jets will be possibly clogged.
if you return it for repair to brother under warranty, make sure its fitted with genuine cartridges otherwise warranty is void
please rate my help++++thanks for using fixya
Apr 16, 2010 | Brother MFC-290C Printer
My ink jet did not print
You must change both cartridge. Instead use completely new cartridge Part No 830 black and 831 colour
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a Samsung fax machine, model SF-3100. It is about 9 years old and has always worked very well for me. Now all of a sudden the print quality has got very poor, very quickly. The first I noticed was...
Try cleaning the print heads with rubbing alcohol to remove any dry ink, also clean the rollers too.
If the unit has a reset button or option i suggest you try that.
Good luck.
Aug 06, 2009 | Office Equipment & Supplies
Won't print black ink 3E
I got a paper jam while printing.Know my brother mfc-290 will not print black
Apr 25, 2009 | Office Equipment & Supplies
Canon mx 310 alarm color cartridge empty
Go to the printer driver (control panel -> Printer -> Right Click your Printer -> Properties). From there go to maintenance tab, Ink Cartridges, Select Black only. Then click OK. Finally hold the Stop/ Reset button for 10 secs or so. It will then work after a couple of warnings.
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
37 people viewed this question
old marine
old marine
