Question about Insignia LCDTV26 26 in. Television
26'' Insignia Startup Screen
I own a 26'' Insignia that is one year old. Upon startup I only get a white screen with snow. After 15 or 20 minutes I get a picture with sound. The ''Please Wait'' screen no longer appears at startup. Any help is appreciated!
    President:
  • 814 Answers
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Posted on May 10, 2009
  • 36 Answers
Insignia 26" bought may 2008 , 18 months later it turns on by itself and starts changing channels all by itself. Tried unplug and plug it back, same thing. Is it asking for a new one?
Thanks
Posted on Oct 12, 2009
IMac screen goes black upon startup
Try a PRAM reset. Probably more than once. http://support.apple.com/kb/HT1379
Sep 30, 2012 | Apple iMac 24 inch 2.4GHz/ 1x1GB/ 320GB/...
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
Briggs engine stutters upon startup
might have unseated a valve check the compression it is good at 100 lbs min to run is 90 lbs thats bad
May 29, 2012 | Briggs & Stratton Garden
I recently downloaded two optional updates for Startup Windows 7 onto my ASUS EeePC 1005. Following download I was requested to restart my PC to complete the installation. Upon restart, I had no display...
Try starting the PC in safe mode (press F8 as it starts) and then restore your PC to a date before you installed the updates.If that fails you must use your windows 7 disk to repair the system or just install it again.....
Nov 04, 2010 | Computers & Internet
5220 nokia hangs during startup
my nokia 5220 does not start. when i press the start button NOKIA appears for a while and after that the screen turns white
Apr 18, 2010 | Nokia 5220 XpressMusic Cellular Phone
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
If I change the startup screen, what happens to the old startup screen?
Except for the built-in preset startup screen, changing the startup screen causes the previous screen to be deleted from startup screen memory. You will not be able to reuse a replaced startup screen unless you have its image saved somewhere else.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Insignia LCDTV26 26 in. Television Logo
195 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
