Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Nozzle replacement The part that controls the flow of the stream of water has come out and needs to be replaced. What is the part and is it repairable?
  • Ann Edmonds May 05, 2013
    We actually contacted BLANCO and provided a picture and they sent free of charge the piece we needed. It was the aerator.
After replacing pump water comes out in short squirts. It seems to come out of pump in steady stream but short squirts at nozzles including hand held.
Check your filters. Flow Indicator Filter: Turn Flow Indicator Cap counter-clockwise to remove, lift rotor and filter out. Clean filter and replace in reverse order.
Sep 03, 2015 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Feb 16, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
A strong continuos flow of water flows through the unit when on. flow is too stong is orfice or solenoid valve broken?
orfice is plugged with calcium and its like a sprayer hose nozzle you need to either clean out copper water tube or replace it
Dec 18, 2009 | Aprilaire 550 Humidifier
The yellow print head is not working. I have replaced the ink cartridge, performed the cleaning and performed the deep cleaning. Yellow is still not showing up on the test sheet.
Try unclogging manually.Warning!!! Next steps may can make your print head not unusable.
Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0050.
Nov 16, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Done all the things you advise to clear the print heads, it seems to relate to the large back cartridge, ink flow seem ok, sponge pad at base of cartridge moist with ink. All other inks fine on test print....
Yes, the print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0075.
Nov 13, 2009 | Canon MP610 Photo All-In-One Printer
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
Nothing printed page is blank, all new ink cartridges lit up red
The print head is clogged.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0059.
Nov 02, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My Canon iP3500 printer is printing pictures that are fuzzy with white lines in them & apinkish-blue color. I replaced all the cartridges. How do I clean the printer heads?
Oct 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Bissell 8930 Pro-Heat wont dispense water/cleaner onto floor, but attachment works fine.
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
Jul 21, 2008 | Bissell Vacuums
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
53 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
