Question about Ryobi Expand-It 2 Cycle 26cc Trimmer Power Head
Ryobi trimmer carb adjustment
How do i get to hi/low adjustment screws,do i drill out blocks or do i have to take carb apart and knock them out?
3 Suggested Answers
  • 85 Answers
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Posted on Aug 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: what are the carb settings for ryobi rct 2800 cb trimmer ,they have been adjusted so the correct position of the screws is not known
Hi peter beaufoy...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Posted on Sep 29, 2012
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
My ryobi rpt3000 don't want to rev up, it starts and idle fine,but not revving up,i did clean the carb and lines, but same problem
When you cleaned the carb, did you count the turns before taking out the High and Low adjustment screws? did you put them back the same amount of turns? The Low Jet is usually the culprit
Aug 16, 2015 | Ryobi Garden
What tool can you use to adjust the carburetor on ryobi gas weed eater
depends if u have the export only carb , because if you have the C.A.R.B. model it's not adjustable (other than idle) , if you have the export only version then there are two small plastic caps on side that can be moved aside and screws can be accessed to set HI and low speed jets
C.A.R.B = California air resource Beauru
Apr 18, 2015 | Ryobi Garden
What are the carb settings for ryobi rct 2800 cb trimmer ,they have been adjusted so the correct position of the screws is not known
Hi peter beaufoy...
Bud
Sep 20, 2012 | Ryobi Garden
Carb screws need adjusted i need to know the settings
Hi. Lightly seat the low screw and bring it out one and a quarter turns. Lightly seat the high and bring it out one turn. Adjust idle screw to suit. Regards Phil.
Apr 19, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
24cc craftsman 2 stoke trimmer. took apart everything and cleaned. new fuel lines. cleaned air filter. ran fine saturday. now sunday bogs out while trying to throttle up or just stalls.
Low side adjustment on the carb needs to be opened up or the carb needs to be overhauled. To open up the low sie, find the carb jet adjustment screws. The screw closest to the cylinder is the low side. Turn the screw counter-clockwise 1/2 turn. You may need to romove tho plastic locks from the adjustment screws, or if it is fairly new, you may need to buy a special tool to use on these screws. The tool is available anywhere that sells Poulan parts. If adjusting the screws doesm't fix it, the carb will need to be overhauled or replaced. Check with www.searspartsdirect.com . Replacement carbs are sometimes cheaper than an overhaul.
Aug 30, 2010 | Craftsman 25cc Gas Line Trimmer
Aug 18, 2009 | Ryobi Garden
Problem with gas trimmer staying started
Carburetor is out of adjustment. there are two carb adjustment screws on the side of the Carb. they require a special tool that is only $5 from your local mower repair dealer. those screws are the idle and Hi speed mixture adjustments. the carbs on Ryobi are set too lean. turn counterclockise to richen the mixture. just turn one eigth of a turn at a time. start w the hi speed.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Expand-It 2 Cycle 26cc Trimmer Power Head Logo
202 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
