Question about LG 52SX4D 52" HDTV
LG 52SX4D 52 in. HDTV Television
White light rolls for a minute, stops on red power signal and blinks a second on light signal. what is the problem? Just barley bought this a year ago.
  • 4 more comments
  • Anonymous Nov 11, 2007
    non
  • Anonymous Nov 27, 2007
    i have this same problem
  • tb09863 Dec 11, 2007
    Same issue. Had toi unplug due to sound quitting and now the light just rolls and then stops on red.
  • Anonymous Jan 17, 2008
    i have the same problem with this tv. same model .any solutions?
  • Anonymous Feb 25, 2008
    i the
  • coldgin Feb 25, 2008
    i have the same problem the white light rolls then the red light bulb flashes
    Problem Solver:
  • 6 Answers
 have had this problem several times i think this is a manufactures default. i am in the proccess of contacting the manufacture email me we can talk [email protected] please let anyone else who is having this problem contact me as well.
Posted on Oct 18, 2007
SOURCE:
I have a Sony KF 50 WE 610 projection screen TV. It has worked perfectly since I bought it six or seven years ago. This morning I turned it on and the sound came on for a second, but then the sound went...
Hello
Five consicutive blinks at a time and the stops and again blinks five; is its self diagonosis procedure. All modern Sony sets has this function included in its circuits. If the system control IC inside it detect any fatal fault inside its circuits system, it will give a signal to its power control unit to shut it down its high voltage outputs to protect the other components from further damage. In your set; as Sony describes; I quotes:-
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Actually the components marked in numberes will not be the same as in your TV. But the fault will it be.
    If you have enough knoledge in electronics and have a concept of soldering and have a good quality multimeter; youreself can do this work by home. OK
    Mar 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
    The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
    The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
    Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
    Maganavox flat screen tv no pic, red light blink codes...
    Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
    Mar 25, 2017 | Televison & Video
    My DLink 5300 G internet camera suddenly says "No Signal."
    1. Remove the Java update and roll it back to the previous state.
    2. If it does not resolve the issue, reset the camera.
    3. Lightly insert a paper clip or a similar sized object into the reset hole on the back of the camera, press lightly and then release the button.
    4. The LED on the front of the camera will begin blinking red and green.
    5. When the LED stops the blinking, the reset has complete.
    6. If the issue is still present, restore the camera to factory settings.
    7. Insert the paperclip or other tool and press on the button continuously.
    8. Wait for the LED on the front of the camera to blink red and green and hold the button through two cycles of blinking (about 5-7 seconds.)
    9. Withdraw the tool after the second cycle of the LED blinking and factory restore has been completed.
    10. Run the installation wizard. If you don't have the installation CD, go to the manufacturer's website and download the software.
    Nov 10, 2009 | D-Link DCS-5300 Network Camera
    No lights on except power light.
    The firmware has been messed up. DDWRT might be incompatible with your router. I would highly recommend to reload the factory firmware or the latest firmware from Netgear's website. Loading 3rd party firmware will void the warranty of your device.
    May 09, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
    Wd 52725 52" mitsubishi
    Good Day;
    Bad news this TV has multi problems, check these:
    1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
    Aug 31, 2008 | Mitsubishi WD-52725 52". Rear Projection...
    Red power button & "lamp" indicator blinks
    Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
    Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
    Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
    Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
    Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
    Slow blinking red light
    Yes you can first try this:. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. LED does not stop blinking after 70 seconds of plug in. Disconnect the USB connector from the card reader to the front from the Chassis, if the unit will then boot up replace the Card Reader part # 299P271010. 7. LED does not stop blinking after 70 seconds of plug in. Disconnecting the USB connector from the Card Reader did not help. Suspect the DM PCB part # 934C116002
    Sep 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
    My tv wont turn on
    youre in trouble check the other posts
    Aug 07, 2007 | LG 52SX4D 52" HDTV
    Open Questions:
    See all LG 52SX4D 52" HDTV Questions
    LG 52SX4D 52" HDTV Logo
    249 people viewed this question
    Ekse
