Insignia tv direct
I accidentally pressed input on my tv and it won't go back to what i was watching what schooled i do
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Do a hard reset and check. Unplug the TV from AC mains wall socket, and re-plug it back after 5 minutes or so. This must make it a hard reset. If it do not help you, the main system control memory IC should be replaced, and set should be initilized.
Posted on Apr 24, 2013
Codes for remote control for direct tv
Insignia TV Code for DIRECT TV is 10463. To program the DIRECT TV remote do the following
1. Slide to TV
2. Press HOLD the MUTE and SELECT
3. If TV Green Light flash 2 times proceed step 4 otherwise goto step 1
4. Release MUTE and SELECT
5. Input 10463.
--done--
Jul 15, 2014 | Insignia Televison & Video
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
I accidentally pressed a wrong button when I was changing back to TV after watching a video. then the screen became snowy and I'm unable to get back to TV mode. I need help!
Hello rgas,
do you know if you have cable or satellite? Look on your remote and for a button called input or source and click on it. Remember what input it is set on first then try changing through each input. See if you get anything. If nothing still, go back to the original input it was on and change the channel to channel 3. If you have cable or satellite, turn it on. If nothing appears, go to input/source scroll through each input and hopefully you should get a picture. Good luck.
-Joe
Aug 30, 2011 | Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a Polaroid tv. My cable company came out today and updated me w/ digital tv and dvr. Things were fine when the tech was here and afterwards I watched a dvd and when I switched the input back to the...
Check the back of your TV. Your cable is probably hooked into a Composite or HDMI input, I doubt they would install it directly to the TV's tuner, these days thats reserved for local antenna's.
Jan 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
