Question about Home
The tub keeps turning it's self back on when you turn it off.
When I tried to turn my jacuzzi tub off today it kept turning it's self back on until I turned it off. I finally had to have someone unplug it to stop it. What could be causing this?
  • 717 Answers
This is a classic problem with tubs that have electronic controls. The only way to solve this is to get the information off the pump or the control box that the pump plugs into and find the replacement.
There are not too many different Mfg out there that make electronic controls so it should not be too hard to find.
You may contact our office for help if you'd like.
Rod
888-521-6183
uspartscenter.com
Posted on May 02, 2013
bigtor1976
  • 21 Answers
SOURCE: My jacuzzi stopped turning on.
I would check all power to the tub. Is it plugged straight to a breaker, plugged into a GFCI, GFCI breaker in the master panel? For it to just stop altogether I would think something tripped.
Posted on Dec 01, 2008
  • 10865 Answers
SOURCE: jacuzzi tub wont power off or on by push switch to
The button is worn out. It should be a relatively inexpensive repair whether you do it yourself or have a technician drop by.
Posted on May 17, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
jasonmteat
  • 111 Answers
SOURCE: Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Posted on Mar 17, 2010
Testimonial: "Thank you so much....I didn't even know that had products like these. I am ordering as I type. By the way, we don't use a well, but I'm sure it will"
SOURCE: Garden jacuzzi tub start button is stuck. It won't pop back up
I called a plumber. He said push the button all the way in, put some 3 in 1 oil on the inside (you'll see a little indent) every couple of months. Also push and release the button quickly. Cost me $80, and he even used my oil!!!!
churchill
Posted on Apr 07, 2010
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
I have a Hyflo jacuzzi bathtub pump. I just tried to turn it on and it hums and acts like it wants to work but it's not pumping. I had this problem with a hot tub pump and all I had to do was blee
If you motor is just humming then it is not starting and is no good.
HyFlo pumps were made by HydraBaths in the 1990's. They are no longer made. We have replacements for them.
Rod
US Parts Center
Feb 01, 2013 | Home
My Jacuzzi Tub won't start
Try compressed air through the system,careful not to use too much pressure. Also you may use another water pump to push water through system and free up the motor. The easiest thing may be to get a new motor though.
Dec 10, 2012 | Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
When I try to turn off my Jacuzzi tub it will not turn off. I pushed the gfi and it went off. I then reset it a few days later and the tub would not turn off and this time the gfi would not shut it off. ...
You will need to have a technician from the store you purchased it from install a new switch.
To be up to code, you should have a GFI for your Jacuzzi to plug into and a GFI circuit breaker dedicated only for your Jacuzzi. I
If you already have it, that's great, but if not check with an electrician for installation.
Regards
Apr 05, 2011 | Jacuzzi Mito, 5 Soaking Bathtub -...
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
59 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
