Question about Ryobi Garden
Ryobi brush cutter fuel tank leaking
Fuel tank cracked on Ryobi Brush cutter 890R
Mike258
  • 1498 Answers
SOURCE: i have a ryobi brush cutter rbc 40sb the pull
Hi there
A chainsaw or small engine repair shop may have the part.
If not, Click here for the Ryobi Service center locator page. Just enter your zip or area code and it will display a list of the nearest Ryobi service centers.
Hope you find this very helpful
Best regards
Mike
Posted on Nov 24, 2009
SOURCE: Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Posted on Nov 30, 2009
dontbother10
  • 2220 Answers
SOURCE: hi im after the fuel mixture for a 125L husqvarna
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Jan 25, 2010
SOURCE: arbor stuck on gear head/bc26
I have the same problem. Any solution?
Posted on May 01, 2010
rycgl
  • 1545 Answers
SOURCE: Hi, I have a ryobi BC30 brush cutter my fuel lines
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Posted on Nov 09, 2010
My ryobi s430 starts well but has lost power. I read about cleaning the spart arrester, running wood in the muffler hole. I have changed the spark plug. the weedeater/brush cutter is 2 years old
Common problem is the fuel pump. It is a small diaphragm in the carburetor. The diaphragm deteriorates, especially with the alcohol in the gas now. You might rebuild the carb. The kits are about $20. Other problems include clogged fuel tank vent, clogged fuel filter (on the end of fuel finder hose in the tank, and clogged fuel jets which is less common.
Mar 19, 2011 | Garden
Starts and runs for about 10 seconds then dies
check the fuel lines for holes or cracks if they are fine then a carb kit may be needed
Jan 05, 2011 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have no spark on my Ryobi Brush Cutter. Replaced spark plug but still no spark.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
Apr 20, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
My Ryobi 77 line trimmers revs like mad when I
Hi and welcome to FiXya. I am Kelly
What your describing it the result of fuel starvation. This can be caused by:
1. Debris in the fuel line or a crack in the fuel line
2 A clogged "fuel tank" internal pick up hose screen
3. A pinched fuel line
4. A clogged needle jet seat
5. A hole in the carb diaphram
6. Debris in the fuel air mixture screw / needle passages
7. A non vented gas tank cap.
Any of the above can cause the symtom you described. For sure it is a fuel supply problem.
I tried crossing the part numbers for just a Ryobi Model 77 and was unalbe to cross it to a working model number.
I came up with 2 different carb part numbers using a 30 CC engine
1st PN: 791-182875
2nd PN: 985624001
If you can pass the exact Model Number, I can provide you with a source for the carb or parts.
Thanks for using FixYa.
Kelly
Feb 15, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Nov 30, 2009 | Ryobi Garden
Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Jun 26, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
29 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
