Question about Garden
Stihl carb adjustment
Stihl FS46 starts and idles fine. At full throttle it sounds and feels as though it is missing, I seem to remember it humming, not stuttering(?). Mine has 2 adjustment screws. The one on the right (closest to engine) adjusts the idle speed. Turning the one on the left has no affect at either idle or flat out. Any thoughts appreciated.
  • 7,482 Answers
Hi Dennis
You have trash in your highspeed circuit.
Rebuild/Clean your carb. Some help below
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 24, 2013
2 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: Stihl line trimmer FS46 Runs good at full throtle
the smallest piece of trash will cause you the biggest problems. try blowing the carb out . i think it has a pre set idle on it.
Posted on Sep 19, 2009
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
FS46. Why does it rev up on its own?
Check the throttle cable, sometimes they get frayed and damaged at the carb end and can stick on.
Aug 09, 2015 | Stihl Garden
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Hello, i have a stihl ts400 and i just rebuilt the topend(crank,piston,cyl,all bearings and seals.Fires up easy, idles fine,revs fine, but when you hold the throttle down it doesent want to hit rev limiter...
There is not an actual rev limiter. The top end is controlled by the carb. You actually want it to sound a bit rich at full throttle so that it has enough fuel when cutting under a load. What causes me some alarm is the revving up part. If it revs too fast that is a lean condition and can quickly ruin the piston and cylinder much like running straight gas. A torn intake boot can cause this. The high speed spec for the TS400 is 9,600 rpm + OR - 500 RPM. Your saw may not have a needle to adjust the high side as some have only the low speed adjuster. Also when you disassemble and clean the carb always use a new kit with the gaskets and diaphragm. Any Stihl dealer can furnish the kits and they aren't terribly expensive. Often between $10-20.
Jun 26, 2012 | Saws
I have a stihl ts-410 cut off saw. it will start and idle but when i squeeze the throttle it dies. how do i adjust the carb?
if this machine ran ok before this problem,and no one has adjusted the carb,then i would check the crank seals.i have just had this problem.and it was the seal on the puller side,though i replaced both whilst i was at it.hope this helps my freind.
Nov 28, 2011 | Stihl Saws
I have a stihl 044, older saw and its not running properly. When I try to start it with the full chock, I get fuel ranning out of the muffler every time I try to start it. I take off the air filter and...
I would say it is flooding, you realy need to pressure test the carb to check the seating of the inlet needle, a simple bulb tester is all you need, connect it to the fuel inlet on the carb ( where the fuel hose is connected ), pump approx 2/3 psi into the carb, it should hold this steady with no leak, any leaks then you will have to fit a new inlet needle, let us know how the test goes.
Apr 05, 2011 | Stihl Chain Saw Handle Models 044 046...
Mighty lite 26b leaf blower will not go full throttle, seems to bog down under full throttle, cant get a tool in the hi and lo adjustments
many current production models have carburetors that have limiter caps on the adjustments (if there are any) and the symptoms sound like fuel starvation or 'lean' condition.
carburetor gaskets/diaphragms should be replaced, and carb body cleaned with carb cleaner while apart
Nov 08, 2009 | Homelite Consumer Products Backpack...
Idle seems too low. runs great, when no throttle, stalls. maybe idle too low. no manual, need to know where idle adjustment screw is
If you haven't already adjusted the carb there are usually 3 adjustments. H - adusts performance at full throttle (how it cuts in the wood). L - adjusts performance at idle and accelleration to full throttle.It sounds as though those are fine. The third adjustment T - is the throttle or idle speed (often away from the other 2). If my saw that is the one adjustment I'd make. You supplied no make or model, it is difficult to provide what you requested without them. HTH
Lou
Oct 27, 2009 | Garden
Sep 18, 2009 | Garden
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
