Question about Imperial IFS40 Deep Fryer
Fryer will only go to 250 degrees
The deep fryer will only get up to 250 degree temperature
    Sergeant:
    Champion:
  • 234 Answers
Need to calibrate the thermostate,or replace it
Posted on Mar 13, 2009
You can also jump the hi- limit switch an see if keeps shutting down, if not is a bad hi-limit
Posted on Apr 22, 2009
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
How long do you cook chicken. Does the green light need to come on before you start frying?
The Onwer's Guide for the Rival CF106-W Deep Fryer is available here:
http://www.rivalproducts.com/manuals/MANUALS/CF106-W_43_76030376.PDF
For deep-fried chicken, preheat oil to 360 degrees F. Bread and then fry for 20 minutes or until golden brown and done.
The surest way is to check the internal temperature of the thickest portion using a tip sensitive digital thermometer. The internal temperature of chicken should reach 165 degrees F.
See here for safe cooking temperatures: http://canfightbac.org/en/cookwell/charts/
Feb 05, 2011 | Rival CF106-W Deep Fryer
High limit kicks out fryer and pilot light can
Since you've mention the pilot light goes out at 400 degree F, then we are talking a gas Deep Fryer. The deepfryer usually use at 350 degree F for chips or else. Because the oil will start breaking down its quantity of frying very quickly over that temperature. Most people set at 350 degree F. Now we comes back to your problem, First you should have a deep fryer thermometer they espcially made for deep fryer, (You only mention 400 or better ) that make me think you're only guessing. Knowing the temperature is very important, most Hi limit is set at 420 degree F.
To me it seen the Hi Ltd control is working and that is why it cutting out the pilot when it reach its limit but we don't know what temperature that when the hi limit cutting out at.
When you have a thermometer, put it in the cold oil and turn the temperature to 100 degree F to see what the temperature control cutting out at. slowly increase your setting until it cutting out at 350 degree F . If you set at 250 degree F and the thermometer already reaching 350 degreen F then don't go any further , your temperature control is defective and need to be change a new one.
This is only the first step, you still have to check out the Hi ltd control to see how good its condition is,so far your information say it cutting out at 400 or better. But you've to be sure, because it is a safety control. Hope that will help you , God Bless.
Jul 05, 2009 | Pitco Frialator SG14 Deep Fryer
Temperature setting for deep fryer
If you have a FryBaby, there are not settings. It will hold a temperature between 380 and 400 degrees.
May 25, 2009 | Presto 05430 FryBaby Deep Fryer
Won't reach temperature
If everything electrically is ok, there might be a reason outside of fryer:
- power voltage is lower then required for nominal power (borrow voltmeter and check)
- the fryer is positioned at drafty place so it get's cooled up by air.
Feb 27, 2009 | Euro-Pro F1066 Deep Fryer
Cecilware Fryer electric
you have a bad high limit the range on this should be around 600 degrees.
Apr 16, 2008 | Cecilware EL-250 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
Imperial IFS40 Deep Fryer Logo
312 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
