Question about Haier HD308 Dehumidifier
Why isn't there any water in the bucket after runing it 24 hours?
After 12 hours of operation, why is there NO condensate in the bucket?
units loose there efficiency over time , five years is a pretty good time for it to work
Aug 11, 2015 | Comfort-Aire BHD-501 Dehumidifier
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
Just bought a dehumidifier in the ground level of a high ranch I am very frustrated because I dump the water every day I waas told to keep the humidity at 45- 50 but it keeps on going up This seems to be a...
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Sep 17, 2011 | Friedrich Dehumidifiers
The dehumidifier motor is on but only extracts tablespoonfuls of moisture from the air every 48 hours. In other words it isn't functioning as it should. Model #DH40; traceability code GR and barcode...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 10, 2011 | Goldstar DH304 Dehumidifier
The Machine turns on and runs fine but produces no water after running for 12 - 24 hour period.
heatman101
Aug 13, 2011 | Maytag M7DH45B2A Dehumidifier
Fan runs but it seems tne compressor does not cool as no condisate collects in the bucket in 24 hours
heatman101
Aug 03, 2011 | Frigidaire Dehumidifiers
I have a Goldstar 305 unit and have been very happy with it for 4 or 5 years. Three days ago I noticed it was running very loudly and for much longer than it usually takes to fill the bucket. The bucket...
The problem you're having sound like the drain tubing to the bucket is partially clogged. But, it is resolvable. Here's what you'll need to do.
Turn the unit OFF & unplug it from the wall. Remove the bucket and at the inside top of the bucket holder, you will see a hole or a tube that drains water into the bucket.
Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in the drain hole or tube. Carefully insert the Zip Tie and work it in, until you reach a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or your run out of usable Zip Tie. Then, slowly remove the Zip Tie while rotating (twisting) it. This will dislodge any clogs. Once you start nearing the end of the inserted tip, be prepared for some water to follow.
After completing the above, reinstall the bucket, making sure that it fits "squarely" from top to bottom into the bucket holder. The bottom should not tilt down at all. Plug the unit in, and turn ON the Master ON/OFF Switch. Lower the humidity extraction level to 32 -35%. If you don't have an LED screen on your control panel, set the manual control to Maximum.
One other thing that you want to do on a regular basis. That's remove and clean the air intake filter, if necessary. Be sure to turn the unit OFF and unplug it, before removing the filter.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Goldstar DH304 Dehumidifier
Model BHD 651-C Serial 611TA000375 Problem: Unit comes on, fan operates but compressor is not kicking in. While the fan operates it is not pulling any moisture out of the air. Controls indicate that...
heatman101
Jun 09, 2011 | Comfort-Aire BHD-651 Dehumidifier
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
Haier HD308 Dehumidifier Logo
41 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
