I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the carriage is locked because I can move it using the release button on the right side (although i can't move it with the tab lever on the right). What am I doing wrong?
  • 453 Answers
Try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Posted on Apr 30, 2013
5 Suggested Answers
SOURCE: carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Posted on Jun 13, 2007
JUSTOLDJIM
  • 453 Answers
SOURCE: Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Posted on Jan 23, 2008
  • 3594 Answers
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Posted on Dec 08, 2008
  • 23 Answers
SOURCE: I can't unlock the carriage on my old Olympia typewriter
YEP, MOVE THE PAPER FEED SELECTOR TO NUMBER 1
Posted on Sep 17, 2010
Where is the carriage lock on a 1950 Royal Portable.
I've seen one on an olympia typewriter. Like a switch on the left side of the machine next to the numbers line. Your problems could be Lock is bent, not connected fully, needs cleaning, oiling.
http://www.ebay.com/gds/How-to-Fix-a-Royal-Typewriter-/10000000205719319/g.html
This link may help. Some of the fix-it advice. Pay attention to carriage won't move paragraph. Check library for possible owner manuals, repair manuals.
Just found this link that may offer more help.
http://www.vintagetypewritershoppe.com/vintage_typewriters_22.html
Dec 25, 2016 | Royal Office Equipment & Supplies
I just bought an old Olympia manual typewriter and put a new ribbon in it. The letter keys are hitting the paper above the ribbon, so the type doesn't show up. How can I fix this?
Laura, are you sure ribbon is in the proper guides and position, if they are, slam the carriage back and forth a few times to un stick the position er.
Feb 22, 2016 | Olympia Office Equipment & Supplies
The keys on my old manual olympia typewriter keep getting stuck what can i do to resolve this. Do they need oiling or what?
Assuming that your Typewriter is non electric spray WD40 on all the mechanical pivot points especially in the segment where thr type bars swing.
DickyO
Jul 26, 2011 | Olympia Supertype 330 Typewriter
Typewriter problem
IF THE CARRIAGE IS NOT MOVING LEFT OR RIGHT, CAN YOU PUSH THE CARRIAGE TO THE RIGHT OR LEFT??? OR IS IT COMPLETELY STUCK. YOU CAN TRY CLEANING THE SILVER SHAFT THE CARRIAGE SLIDES ON AND LUBRICATING THE SHAFT WITH A LIGHTWEIGHT OIL, WHEN YOU PRESS THE KEYS DO THEY WORK.???
Mar 18, 2010 | Olympia Mastertype 3 Typewriter
Carriage remains stationary when typing. Is there a way to unlock
Mant portables have a lock to hold the carriage in place while in the case, on the rt. or left sides below the carriage.
Hope this helps
DickyO
Apr 14, 2009 | Olympia Office Equipment & Supplies
How to oil/lubricate an old Olympia AG/SM ? typewriter
Hi..sewing machine is ok, a little too light but ok. Move your margins all the way out so that you carriage can move its full length.
If you look at the underside of the carriage you will see what they call Rails. These are tracks in which the ball bearings reside. 4 or 5 drops of oil on these and the bearings will be lubed. I use a little heavier grease not oil, but light oil. Too much oil is worse than none.
I think you problem is in the carriage return clutch..something that should be handled by a Pro.. Too many parts, springs and broken adjustments for the layman. Some times you can spray 1..I repeat 1 small shot of degreaser on the carriage return clutch (located on the right side, middle of the typewriter. Usually has a fabric band winding around it.
If not a Pro can help you..
Hope this helps.
Squipps
Jan 02, 2008 | Office Equipment & Supplies
Olympia Startype 3 Typewriter
Does it make a grunting noise? If so, it needs a couple drops of oil on the main support shaft. Also check the indent setting. You need to use the code key to activate or deactivate the indent.
Aug 16, 2007 | Olympia Startype 3 Typewriter
181 people viewed this question
jasbo
jasbo
