Question about Frigidaire FRS26R4A Side by Side Refrigerator
The fridge ice maker isn't getting water
I have a fridgidaire side by side fridge the ice maker isn't getting water and the tube freeze's up.
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check close to the end I have suggestions on how to stop or eliminate delivery tube freeze ups.
Does it make Ice OK?
If so the ice-water valve may be at fault if neither work.
Eliminate water filter or frozen line to reservoir.
Make sure you have water to water valve
Shut off water, remove line, open water line. Catch water in container and examine. Clean on particles let it flush out some more open and close til clean. Verify pressure and flow.
Still no water?
Check voltage with a volt meter at the fill valve behind the refrigerator.
Attach volt meter to the coil wire plug just insert probes into them. Then push the button on the door like your getting water. No volts? If has Ice maker pull off the other set of wires on water valve and recheck with door switch. Still no power? Problem in the ice - water door relay or control board.
If these check OK water valve is not opening when power applied replace water valve. Power shows good replace water valve.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need an Ice maker book to tell you what it could be and what to look for.. Too many items to mention here.
I recommend if your problem is actually the ice maker itself get a new or rebuilt one. Too many things to detail to make sure it all works out in the end. However you might replace it and still have a problem. So here is a list of items to check external of the ice maker to eliminate what might be something else.
First lets see if we can eliminate some things:
Itemized as Temperature, Water, Water delivery… It is assumed the refrigerator has been running and not making ice and has remained on (NOT UNPLUGGED AND OFF) freezing as normal before starting any of these tests and observations. Other wise you will have to start over with the problem at hand before proceeding.
External of the ice maker:
1st Does the Freezer temp get down to 12'F? . The temp of the freezer has to be this cold or colder for the ice maker to work. Just because meat stays frozen (28’F and colder) doesn't mean it will freeze ice (12’F and colder) and dump it out. You have to know and record your findings to be objective and not subjective.
If not your problem may not be the ice maker at all. Eliminate it as a source of heat in the freezer. It’s plugged into the wall of the freezer and has a heater that warms the ice up to turn it loose for “harvest”. Unplug or remove it. Recheck the temp after ½ to 1 hour with the doors closed during this time. If its still not to temp your ice maker may be ok.
A lot of things can cause the temp of the freezer to stay high. But if this is the situation you need to look for a different problem before condemning and buying an Ice maker replacement
2nd Does it get water into the ice maker? If the water isn't getting to it you need to check the water delivery system, water supply, and water valve in the back.
The water delivery is easiest to check by shutting off the water removing the supply line and catching the water in a container with the valve open 1 to 2 rounds to flush out any particles and verify good flow and pressure, and makes sure when you turn it on you have clean water..
After you have eliminated this;
Next if your not getting water to the delivery tube and into the ice maker
1 of 2 things is stopping the water. Either its: 1 mechanical or 2 electrical in nature.
Mechanical
The easiest to look at is the obvious first. The water is not falling off the delivery tube? Look inside the freezer. Make sure the opening of the water delivery tube in back or side of the freezer is open and does not have ice or frost on it. Ice, here, can freeze and close off the delivery system. A common problem is lime or scale buildup, causing this ice to form. If the tube has this problem, defrost it with a hair dryer. Clean the tube with lime away or CLR. Re try it.
Posted on Mar 22, 2009
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
I Ice maker keeps freezing and it builds up so
Either your water flow is too strong, your fill tube has dislodged from your Ice Maker, or your water valve is clogged with lime and defective.
I would opt for the obvious culprit, the fill valve. These are easy to replace and not expensive. First turn off the water to your refrigerator. Pull your fridge from the wall and follow the opaque tube at the top of your fridge down to the little aqua blue device with 2 wires connected to it. Note that fridges with cold water and ice have a dual valve with 4 wires but look similar. There will be 1 or 2 screws holding that in. Remove that valve and record the model number. Call either Searspartsdirect.com or 1stsource parts for replacement, or find a local dealer who has good prices. Replace the hoses in the order you removed them and you should be fine.
Mar 13, 2010 | Maytag MZD2766GES Side by Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
I ice maker keeps freezing in our side by side GE fridge.
This annoying problem can have a variety of causes. Check these four things first:
  1. Make sure the water supply is greater than 20 psi. If too low, thewater valve won’t seat properly and it’ll “weep.” Common causes of lowpressure are gunked-up saddle tap valves, kinked water supply line, andusing a reverse osmosis filter to supply water to the icemaker.
  2. Check between the valve diaphram and valve seat for sediment. If found, do not attempt to repair, buy a new valve.
  3. Check to see if the black, flexible portion of the fill tube iswrinkled, twisted, or kinked which can cause ice dams that block thefill tube.
  4. Find out if the water has been shut off while the icemaker has kepton cycling. This, too, can cause the fill tube to freeze up.
If all the above checks out and you’re still getting fill tube freeze-ups,then best get a service guy to take a look. It could be a complicated repair.
Jun 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Apr 08, 2008 | Frigidaire GLRS267ZA Side by Side...
Freezing food and leaking water
faulty water valve will cause the issues with the ice maker fill tube , possible faulty air damper will cause the fridge to get too cold
Jan 07, 2008 | GE PSS25NGM Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
428 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
