Question about Regal Lager Phil & Teds Vibe Jogger
My front wheel of my pnt vibe is starting to sit at a slant my two kids re only 41 lb combined should i just send it back? its only 7 months old x
We had a bent front wheel axle on a NEW Vibe. We just asked for a replacement wheel under warranty, but a new wheel has a thicker attachment piece and, as a result, doesn't swivel properly. Your best bet is to get a front wheel replaced and hope that it fits as it should! Here you can find an official distributer in your area:
http://www.philandteds.com/stockists_08_1.htm
Posted on Nov 20, 2009
I have just bought a second hand phil and teds vibe and have noticed the front wheel is on a slant too. Just wondering if you were able to fix this problem you or did you end up getting a replacement stroller.
Hope you can help!
Thanks
Posted on Sep 23, 2009
Axle nut torque
Front Propeller Shaft Retaining Nut
181 N·m
134 lb ft
Jan 27, 2017 | 2006 Pontiac Vibe
2004 ultra classic torque spec's on front and rear axle nuts and front and rear rotors with front dual rotors
Tighten the rear axle nut to 60-65 ft.-lb. (81-88 N•m).
Front axle nut
FXST, FLSTC, FLSTF,
FXSTB and FXSTD 50-55ft/lbs - 68-75 NM
FLSTS and FXSTS 60-65ft/lbs- 81-88 NM
Brake disc bolts
Front wheel 16-24 ft/lbs- 22-32nm
Rear wheel 30-45 ft/lbs- 41-61nm
Aug 11, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
Front wheel is slanted
Outer tie rod end or upper ball joint is broken off.
Mar 01, 2014 | 2009 Pontiac Vibe
AWD
The AWD feature is on all of the time and can not be turned off.
Dec 10, 2009 | 2006 Pontiac Vibe
Front wheel wobble on phil & ted vibe
ya the is a front bearing that might be out of line contact outnabout they are the importers for phil n ted. Or if you live in London go to www.buggypitstop.co.uk they do repairs on all brands of pushchairs. Thay are very professnial
Nov 22, 2009 | Baby Gear
Phil and Teds Vibe front wheel doesn't swivel
I had this problem 4 times with mine!!! the company tried to repair (unsuccessful) and then replaced it. The same problem occurrred with the second one after a month. Phil and Ted's took it back and put a thing called "super lube" on it. At first it was no better, but with a little use it seems to have come good.....for now. This is a terrible stroller that I really regret buying!!!!
Nov 19, 2009 | Baby Gear
Phil & Ted's Vibe very stiff front wheel
Hi
I am onto my third Phil and Teds Vibe due to issues with the front wheel. It never ever worked smoothly from the moment it was assembled. The first time the UK distributors Outnabout replaced the pin - no help. The next time they replaced the entire no buggy. The new buggy is exactly the same - stiff front wheel that is back breaking to turn and squeaks loudly. Interestingly, I am waiting for Outnabout to send some lubricant that Phil and Teds have recommended; despite being told by the retailer in no uncertain terms NOT to use lubricant. I plan to return the third and final buggy and ask for a full refund or partial refund and replacement with a Sports buggy model. The wheel mechanism is different on that one. Good luck. As you can see, I am all out of answers.
May 07, 2009 | Regal Lager Phil & Teds Vibe Jogger
2004 Ford Explorer front shocks are worn out
Remove the front wheel.
Locate and remove the 3 nuts on the upper frame mount,top of the shock.(torque 20 ft lb)
Remove the nut on the sway bar link.(torque 18 ft lb)
Remove the lower bolt that goes thru lower control arm and shock.(torque 258 ft lb)
Then use a spring compressor to compress spring and remove the nut on the spring plate.(41 ft lb)
Apr 15, 2009 | 2004 Ford Explorer
We had the same problem when we bought our Dash, 2 weeks ago.
When we compared it to an other Dash from one of our friend it was unbelievable. We exchange our wheel and we undersatood that the problem wasn't the wheel but where you put the wheel.
We cleaned it and removed the excess of paint with a light sand paper.
The result was magical, now it works really well, we can turn just with one finger.
Hope that helps.
Jan 27, 2009 | Phil & Teds E3 Jogger
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. rroszman@yahoo.com
Dec 09, 2008 | 2001 Jeep Grand Cherokee
Regal Lager Phil & Teds Vibe Jogger Logo
270 people viewed this question
Top Regal Lager Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you a Regal Lager Baby Gear Expert? Answer questions, earn points and help others
