Question about Royal 29043x Alpha 1000 Ml Cash Register
I can't read the information from the control journal and z reports on my SD card.
I have tried different SD cards and even reformatted them, but when I try to open the files they have and .ecr file extension that I cannot open. I have tried to look the information up on the web, but all the information I find says that it is an encrypted email file. I'm not sure what to do.
I formatted my micro sd card on my Galaxy S5 like it told me to do, but my computer keeps saying that it needs formatted.
Different devices do not always recognize SD cards formatted by another device. To preclude losing your information, transfer information using a cable. If you reformat on your computer, you may have to reformat again to use in phone.
Mar 05, 2015 | Cell Phones
Olympus Stylus 300 keeps reporting card error on different cards. Tried reformatting and the error persists. What to do?
First, try a factory reset on the camera just to be sure it's not something that easy to fix. Also, format any SD cards first in your PC and then format them in the camera if it will allow it.
If that doesn't work make sure the pins inside the card slot are not dirty or damaged. You'll need a strong light and maybe some magnifying glasses. Try blowing a burst of canned air inside but make sure you're holding the can level so you don't spray the propellent.
Nov 06, 2014 | Olympus Camedia Stylus 300 Digital Camera
Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
Mar 23, 2017 | Audio Players & Recorders
Free canon manuals
Take the memory card out of the camera. Move the lock switch on the side of the card to the unlocked position if it is in the locked position. Replace the card carefully without moving that switch.The unlocked position on most SD cards puts the switch towards the end of the card that goes into the camera first.
If that doesn't help, try a different card. The card you are using may have a problem that could require formatting. Copy your photos to another drive first. (Use a drive/photo recovery program on your computer (with the card in an SD card reader). There are some that will attempt to read even a corrupted SD card.) Then reformat the card. If the card can't be reformatted, it may have failed. Check your warranty on the card and see if it will be replaced by the manufacturer.
I hope this helps.
May 11, 2013 | Canon PowerShot SD850IS Compact Travel...
Polaroid tablet 8-in wont accept any sd cards?
Look for a format command within settings on the tablet. Also, there are different types of SD Card.
SD card TYPES - Google Search
Apr 08, 2017 | Cameras
Unwrite protect Micro SD card?
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your sd card drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your sd drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Jun 22, 2012 | SanDisk 4GB microSD High Capacity Memory...
The 16 GB SD card came preinstalled with my Droid X. Worked fine for a while until it stopped working, Phone said it needed to be reformatted, thus loosing all information. After a few tries of...
If your SD card cannot be formatted and your phone cannot read it, you will simply need a new SD card. That is the only fix.
-ex Sprint rep
Jul 15, 2011 | Motorola Cell Phones
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Olymus 1gb sd card could not reformat
in this case Im sorry to inform you that will not be any data available on that card cause it should have been formatted before use...or ..it is damaged thats why it is not reads on it ...but a thing to try is to see if it is not locked on the side button ..for securing data ..at least after unlocking you can format it ..and use it ...
also see that it needs to be formated in FAT32 ..for to be usable in the camera
Jan 27, 2010 | Olympus FE-230 Digital Camera
Micro sd
BLBOW ON THE METAL STRIP ON THE SD CARD AND IN THE SD CARD SLOT ON UR COMPUTER
Jul 24, 2008 | Nintendo DS Lite Console
Royal 29043x Alpha 1000 Ml Cash Register Logo
76 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
