Question about Whirlpool WRF736SDAM 26 cu. ft. French Door Refrigerator
Refrigerator demo mode - Whirlpool WRF736SDAM 26 cu. ft. French Door Refrigerator
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Tip
How to reset it out of demo mode
If your not getting any response out of your control pane you will have to do the following
The refrigerator may be in Demo mode which disables the compressor to save electricity when the refrigerator is on the showroom floor. To cancel Demo mode, press Freezer and Arctic Select Zone buttons for 8 seconds. You will hear a chime.
on Dec 25, 2008 | Samsung RM255LASH Side by Side...
Display shows OF and OF
Your refrigerator is in Demo mode, which also shuts off your compressor.
To get out of demo mode, most of the older Samsungs are programmed so that if you press and hold the top left button and the one directly below it (for about 5 seconds or so until you hear a ding), the unit toggles out of demo mode.
Aug 14, 2015 | Samsung RF4287HA
It is showing a code: OF followed by oF
Your refrigerator is in demo mode. For a detailed description of how to get refrigerator out of demo mode, press the two button on the upper left side of display for 3 to 5 seconds or until the OF dissapears. If your refrigerator does not have a display on the front side, do a search for "how to take samsung refrigerator out of cooling mode/ demo mode" and it should give you several options available for your model of refrigerator.
Hope this helps
Mar 03, 2015 | Samsung RS265TDRS Side by Side...
TURN DEMO MODE OFF
Thank you for your post, friend!
In order to take your Frigidaire refrigerator out demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. If you could follow up with a post I would greatly appreciate it. -Matt
Feb 15, 2015 | Frigidaire Refrigerators
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
How do I take a samsung refrigerator out of demo mode?
Press "Energy Saver" & "Freezer Power" buttons and hold for 3 seconds.
Jun 20, 2014 | Samsung RF4287HARS French Door...
Can't get out of demo mode
On most, if not all similarly styled refrigerators, demo mode is toggled off and on by holding a combination of buttons on opposite sides of the display. Which buttons can depend on manufacturer, model, and display or button layout. For most LG refrigerators, it should be the "Refrigerator" and "Ice +" buttons. Hold them until they sound a beep to indicate a change in the demo mode status. It should not take more than 10 - 30 seconds.
If that does not work, and there are other buttons on opposite sides of the display, then try the other opposite pair of buttons.
Apr 05, 2013 | LG LFX25978ST Bottom Freezer French Door...
How do I get samsung refridgerator out of demo mode
Your refrigerator might be in Demo Mode - also called Sales Display Mode - if it displays OFF or if the lights are on but the refrigerator isn't running. How to turn off Demo Mode varies for different models. Try one of the following:
-- Unplug the refrigerator for 60 seconds and then plug it in.
-- Press and hold the HOME key and HELP key at the same time, for 5 seconds.
-- Open the refrigerator door and then press and hold the ICE PLUS/ULTRA ICE key and REFRIGERATOR TEMP key at the same time, for 5 seconds. The door must be open.
-- Press and hold the ICE PLUS/ULTRA ICE key and the up/down keys, for 5 seconds.
-- Press and hold the EXPRESS FREEZE key and the REFRIGERATOR TEMPERATURE CONTROL at the same time, for 5 seconds.
Feb 13, 2011 | Samsung Refrigerators
Whirlpool WRF736SDAM 26 cu. ft. French Door Refrigerator Logo
387 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
