Question about Bissell 7950 ProHeat Upright Wet/Dry Vacuum
How do we fix a broken upright stop? the upright stop will not stay up. something is not right.
  • Official Brand Answer
  • 315 Answers
Hi Jeremy! You may want to have one of our techs at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Apr 25, 2013
What can I do to fix Panasonic vacuum MC-V7395 that will not stay locked in upright position?
Most vacuums have plastic tabs and a plastic mechanism of some sort to that will engage those tabs to make it stay upright.
I am suggesting either the tabs are worn down, or are broken off, or maybe the locking mechanism is broken.
These parts are most often not replaceable, unless you can find an identical machine with these still good on it, and swap whatever parts are necessary to fix it.
Machine is a "throwaway " model.
When it breaks, you are expected to buy a new one.
God bless your efforts.
May 02, 2016 | Panasonic Vacuums
Why did the agitator stop?
Bryan,
Most of the time, when a brush stops, you either have a broken belt or there is something wrong with the brush. If the brush spins very freely when you try spinning it by hand, you have a broken belt.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
How to tighten Oreck XL upright position to stay upright
The detent that is mounted to the inside of the housing is probably broken off and the only way to get that fixed is to replace the housing. If you have been getting regular tune ups at a service center there may be the possibility of getting that done under warranty depending on how old your vacuum is and how long the warranty period is for that vacuum.
Jul 05, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Vacuum won't stay in the upright position
I believe you have a broken handle release pedal. It make look intact, but if you turn it over and look where the lever is fastened to the body, it should protrude out another inch to an inch and a half. If you don't see this, then the plastic "spring" part of the lever has broken off; this is what forces the lever to stay up. the part for the Helix should be # 203-2463 and should be under $10.
Nov 15, 2013 | Bissell Cleanview Helix Vacuum
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
Vacuum won't stay on. When I push the button to start it, the motor shuts off as soon as I let go of the button.
You have a broken switch (replace) or hopefully something caught under the switch. Regards Billy
Dec 21, 2010 | Dyson DC14 All floors Bagless Upright...
Eureka 5841 Upright Vacuum Handle will not latch to stay upright
The pedal is probably broken or stuck. You should be able to see where it catches when you stand it upright and determine why it won't catch.
Jul 21, 2010 | Eureka 5841 Upright Vacuum
SteamVac F5914-900 SpinScrub won't stay upright or collect water
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Upright lock broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559827
Generic problem for all Vacuums
Upright lock broken
Posted by diamond8990 on Apr 30, 2008
Upright lock broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and the model # it sounds to me that you have a broken handle release if that is what you are referring to as “Upright Lock Broken” – the handle release lever keeps the hand staying up and in the upright position. So include @ least the brand name and or the model # and I can try to further assist you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Kirby Ultimate G Upright won't stay up right
I figured out that when mine did the same thing, it was time to change the bag. It was too heavy for the handle to handle! LOL Hope that helps. Tracy
Jul 26, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
127 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
