Question about Car Audio & Video
1997 Ford Explorer Radio will turn on but no sound When i first turn it on it says {Phone} then switches to tuner
    Scholar:
  • 191 Answers
Its either in a bluetooth phone mode, or the deck is bad.
if its bad, remove the deck and throw into nearest trash can.
Posted on Mar 16, 2009
  • unit01 Mar 16, 2009
    alternatively you could unhook the car battery over night and then re-hook in the morning to see if a reset will fix the deck.
Radio turns on and off automatically and changes from tuner to CD searching for a disc every two/three minutes on its own! What's up with that? 1999 Ford Explorer - just purchased!
Sounds like a faulty radio or radio power connection, as you've just bought it, I'd go back to the dealer and ask him to check it out, after all, it should have some kind of warranty.
Sep 01, 2011 | 1999 Ford Explorer
No sound from radio in 97 ford explorer already r...
Turn the radi volume up high
Can you hear any hiss or noise?
If Yes..then the problem is your radio or aerial.
If NO , then the problem will usually be the speakers
Check connectors+wiring
May 21, 2010 | 2002 Ford Explorer
1997 Explorer Sport no sound issue
sounds like a bad radio install or radio is bad
Jun 03, 2017 | 1997 Ford Explorer AWD
Where is the amp located for 1997 ford explorer. I am trying to install an aftermarket radio. I have the harness that I need, but where is the amp and the antenna lead tuner box located in the vehicle?
right side above the rear wheel well -you have to remove the panel which has fasteners everywhere and a few screws under the carpet-might have to get a special antenna adapter too- ford premium stereos are weird like that-good luck
Nov 24, 2009 | JBL GTO755.6 Car Audio Amplifier
Where is the ignition switch on a 1997 ford
if it is making a rapid clicking sound while trying to start it, your battery is not fine. you can try to jump it. hook up the cables properly and allow the vehicle to sit for about 3-5 minutes. allow the "jumping" vehicle to just idle. reving the engine will not do anything.
Nov 09, 2009 | 1997 Ford Explorer AWD
4wd high and 4wd low lights flashing at same time on 1997 ford explorer and often engages 4wd when not needed.
possible solution is to take out your dash control panel which has 2 screws . pull it out the radio and all will come out and check the wirer behind the switch. see if it is louse or disconnected also you could need a new switch
Oct 08, 2009 | 1997 Ford Explorer AWD
Were is the Radio Amp in a ford XLT Exployer 1997
I solved the problem I just made sure I wired according to the wires on the radio I took out
Jan 24, 2009 | 1997 Ford Explorer AWD
Radio lights off on 1998 ford explorer
1 -Check your head light switch and turn signal switch by taping them lightly - Common problem with fords to short signal light switch/head lights and they also have radio lights/clock lights control(lights dim for Radio/clock when you turn the lights on)
If you have checked all the fuses and switchs, possible that the light bulbs have burned out. Check with a local radio repair shop and they can remove the radio and install new bulbs.
Dec 02, 2008 | 1998 Ford Explorer
No sound coming from deck
check the remote wire(the blue with white) is it giving 12 volts to the factory amp? some ford have amps that needs to turn on when the radio turns on.
Mar 17, 2008 | Alpine CDA-7863 CD Player
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
