Question about Remington Garden
Can not tighten the chain because the screw is bent.
The chain guard adjusting screw is bent so that I can not adjust the chain. This is a plastic piece that holds the chain in place. I tried to buy the part and can not find a dealer. The screw is attached to plastic and I am afraid that I will break the piece if I try to straigthen the screw.
  • Anonymous Apr 10, 2009
    The plastic "lip" that holds the adjusting screw in BROKE! Now I find out that Remington has gone out of business. How can I get the chain guard (since that has the screw in it). I assume I need to replace that entire plastic cover - there's no way to fix the plastic lip. I have the 16" Model M30016AS - it's less than 6 months old!
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
steve_lima
  • 181 Answers
SOURCE: Is it possible to adjust the chain break & how to do it.
hate to say this,but,there is no way to adjust the tension on the brake band.either the spring is weak or the brake band is broken.either can be changed but it's not easy.spring is under a lot of tension and can fly out when taking it apart or installing,you can get the entire cover as a unit if so desired...hope this helps,let me know
Posted on May 13, 2009
  • 323 Answers
SOURCE: The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Posted on Jun 08, 2009
  • 10865 Answers
SOURCE: Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Posted on Jun 11, 2009
How do you tighten the chain
There are a number of different adjuster types, manual and tooless, manual adjusters will have a screw driver slotted head screw either on the front of the saw or at the side, slacken off the bar nut/nuts turn the screw clockwise to increase the chain tention, tooless adjusters will have a large plastic nut with a fold out wing to aid removeal, slacken this off there will then be a thumb wheel to turn which will adjust the chain.
Jun 23, 2012 | Poulan 14" Chainsaw
Chain dowsn't stay tight
Between the chain bar and the body there is an adjusting screw, if the adjusting screw is stripped it will not pull on the chain bar to tighten the chain.
procedure for tightening chain. loosen the chain guard nuts, tighten the bar adjusting screw by turning to the right or clockwise, the chain has to roll freely around the bar but not bind. check with gloves or rag, don't use bare hands to avoid accidents. once chain is adjusted, tighten the chain guard nuts. good luck!
Oct 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace my chain on my Partner brake assisted chain saw ?
Make sure the brake is de activated by pulling the hand guard fully back to the top handle, you shpuld hear an audible click when it locks, remove the nuts and side cover, the chain adjuster will either be in the crankcase or the side cover, screw the adjuster right back, remove the old chain, now loop the new chain over the sprocket and lay it into the guide bar with the cutters on the top of the bar facing away from the saw, re fit the side cover making sure the adjuster pawl locates into the adjuster hole in the bar, re fit the bar nuts finger tight, screw the adjuster up so as the chain sits snuggley all around the guide bar, pull the chain around manually with a gloved hand, this will make sure it is properly located in the sprocket and is free in the bar, lift the bar nose and fully tighten the bar nuts
Jan 23, 2011 | Garden
Chain came off a 14 mcculloch how to put back on
Hi, you need to remove the plastic guard on the side, held in place by a nut and a screw. Replace the chain around wheel and chain guard, loosen tightening screw, replace plastic conver, and tighten tightening screw. Make sure you have the chain the right way round, there is usually a small diagram showing this. Hope this helps
Jul 12, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How do I reattach chain after it slipped off
Normal 0 This will be the basic instruction for most common saws. Check that the chain brake is in disengaged position by moving the front hand guard towards the front handle if the saw is equipped with a chain brake on the handle. Loosen the bar nuts on the clutch cover. Loosen tension screw or other adjuster (thumbscrew) to allow the bar to be moved toward the engine. Some saws have this tension adjustment built into the bar. This will provide enough slack in the chain to able to reinstall it. It may be necessary to remove the side cover to gain access to the clutch/gear assembly on the side of the engine if the chain also jumped the gear here. Remove the cover, inspect for any debris or other obstructions in this area. If none, replace the chain back over the drive gear and in the bar groove all the way around the bar. It may be necessary to turn the bar adjuster screw more to provide enough slack in the chain to do this. Once the chain is in place reinstall the cover and bar lock nuts. Snug up the nuts but do not tighten these. Turn the bar/chain adjuster screw to tighten the chain on the bar (take up slack). I usually tighten to a point where there is no slack between the chain and the bottom of the bar and I can still turn the chain easily around the bar by hand. With experience you will get the feel for this chain tension. Once the chain is properly tensioned, tighten the bar lock bolts/ nuts on the side cover. I hope this helps you out.
Jun 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not move on chainsaw
Some Poulan Pros have an adjuster screw on the front of the engine case right beside the bar, some have a tool less adjuster on the clutch cover, and some have a slot in the bar for adjusting the chain tension.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Mar 21, 2010 | Remington Electric Chain Saw
I just bought a La Jolla 26' men's bike and the pedal stem is scraping on the chain guard. How and where do I make adjustments?
Examine the top of the chain guard where it mounts to the bicycle. Loosen the fasteners enough to slide the chain guard in and out. Adjust it so it doesn't hit the crank or rub on the chain and tighten the fasteners back down.
Jan 19, 2010 | Cycling
How do I tighten chain on Model Poulan 2050. Can't seem to get tight enough.
Hold the nose up!
c581361.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Nov 18, 2009 | Poulan Garden
Garden Logo
171 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
