Question about LG LMU240CE/LMN120CE Air Conditioner
Shut down and has unknown error code
One of my two indoor units has stopped working. The green power indication light flashes six times before pausing and repeating. Does anybody know what error code this is?
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
hvac1960
  • 2133 Answers
SOURCE: I have got a problem
Inverter compressor run current high. Check compressor windings all equal 1 to 4 Ohms, Check to earth 50 MOhm minimum, check run current. If it's high, or windings open circuit, replace compressor.
Helpful?
Posted on Jan 20, 2011
  • 11800 Answers
SOURCE: I have a problem with
3 blinks - return air sensor , the sensor that measures the temperature of the air going in the internal unit is reporting an excessive temperature or nothing at all.
8 blinks - fan failure
No, you can't repair it yourself, the control board, sensor and fan will have to be checked and most likely the fan motor replaced.
Posted on Sep 03, 2011
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Initially fan in indoor unit was surging,cutting in and out,now has stopped completely and red/green flash twice followed by red flashing 4 times
The flashing indicates a fault code. Not knowing what make / model you have makes it impossible to determine the exact fault. If the indoor fan was running erratically, it may just be a fan capacitor on the indoor unit. Some units have a separate capacitor, some have the capacitor mounted on the main indoor control board. Check and see if the fan starts if you give it a flick to start it spinning when you turn the air con on. If it runs and the error flash does not appear, then you will know its a fan capacitor.
Apr 12, 2015 | Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
May 11, 2013 | Sharp Heating & Cooling
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
It shuts off and blinks 11
AHX18MEV
4 - 12
1. Indoor unit
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
How do you retieve the error codes?
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
Jun 03, 2010 | Mitsubishi WD-65732 65" Projection HDTV
LG LMU240CE/LMN120CE Air Conditioner Logo
19 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
