Question about Garden
Fluid Transmission Type for 1972 John Deere 544 wheel loader?
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
miket756
  • 2702 Answers
SOURCE: John Deere 210 C backhoe loader - quesion on hydraulic fluid
yep there is!
Posted on Jul 13, 2010
  • 123 Answers
SOURCE: john deere 185 transmission
The easiest to check would be to remove the wheel and check to make sure the key is in the shaft on the axle. The rear wheels are keyed to the axles from the transmission and they are possible to shear. Also when the wheels are removed there will be an e-clip holding the wheels on. If one has broke that could be a reason your wheel seems to be coming off. If all there checks ok, the transmission will have to be replaced as John Deere does not make replacement parts for most and if they are available it is cheaper to replace the transmission. Let me know how you come out and if you need any more assistance, Daniel.
Posted on Nov 18, 2011
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
John deere troubleshooting
check fluid level, if full first inspect the valve, if the valve is passing fluid check ram for leaks, most will leak a bit of they are older however a large leak can introduce air to the system and cause cavitation. be sure the right type of fluid is used, the wrong type will burn up your pump
Dec 11, 2013 | John Deere 240 and 245 Farm Loader...
Diesel loose prime on my john Deere 544 loader
You have an air leak or a bad valve somewhere. Check every connection.
Nov 07, 2013 | Cars & Trucks
J Deere LX277 has stopped. Engine is running great,,,wont go forward or back...transmission fluid level is good..help
I don't have a John Deere. Had a Wheel Horse once; same problem. There is a transmission switch in back beside the right rear wheel; slides in and out. MAYBE this helps!
Mar 21, 2011 | Computers & Internet
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Mar 26, 2009 | Garden
Garden Logo
395 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
