Question about Maytag MEDB850WL 29" Electric Dryer 7.3 cu. ft. Capacity, 9 Drying
Dryer will not get hot - Maytag MEDB850WL 29" Electric Dryer 7.3 cu. ft. Capacity, 9 Drying
  • Maytag Master
  • 2,259 Answers
The likely causes of the problem, in order of most common to least:
1) Th heating element has failed (broken) and needs replacement.
2) One of the "overheat thermostats" has failed, needs replacement.
3) The heater fuse has blown, if your machine has one.
4) A wire has burned in two, often near the heat element in the back or bottom of the machine.
5) A wire has burned in two at the connection (from the plug) inside the back of the machine.
6) A circuit breaker has "tripped" inside your fuse box, located in your garage, hall, basement, or wherever.
Be blessed.
Posted on Apr 23, 2013
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 28, 2015 | Kenmore Dryers
Why does dryer gets super hot
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 02, 2014 | Dryers
Dryer gets very hot
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 17, 2011 | Kenmore 72622 Gas Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
WHAT TEMPATURE SHOULD A DRYER REACH TO DRY CLOTHES AND WHAT REGULATES THE DRYER HEAT
heatman101
Aug 14, 2011 | Whirlpool LEB6200 Electric Dryer
Dryer is getting too hot
heatman101
Aug 10, 2011 | Whirlpool WED5300S Electric Dryer
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
When the dryer is running top of dryer where controls is hot to the touch
heatman101
Jul 29, 2011 | Hotpoint NVL333EY Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Maytag MEDB850WL 29" Electric Dryer 7.3 cu. ft. Capacity, 9 Drying Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
