Question about Canon Bubble Jet i80 InkJet Printer
Can,t install ink tanks
No user manuel can't figure out how to open printer and install ink tank
Open the cover, remove/replace
Posted on Mar 13, 2009
My large black ink cartridge with not print correctly on my Canon Pixma MP830. All the other colors work fine. I've done numerous cleaning and deep cleaning. Then replaced the cartridge and it still prints...
Are your black ink cartridges genuine Canon ones?
Are the contacts clean when you remove the cartridge?
If not blow off with compressed air and a clean brush, if necessary.
Canon.com's site covers the verification that the cartridges are installed correctly below:
Issue: Black ink does not print
Solution: Confirm that the recommended ink tanks are installed properly MP800R / MP830
Replacing an ink tank When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. Recommended Ink Tanks:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note:
    When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Check the ink tank. If the orange tape is as shown in Figure <1>, it is properly removed. If the tape is not removed (as in figure <2>, pleease remove the extra tape).
  6. Insert the ink tanks into the print head.
    Note:
    Press the mark "PUSH" on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  8. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Jul 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Ink tank
Greetings,
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Canon MP830 All-In-One Printer
Tip
Duplicate Cartridge Error - Which one is causing it
The purpose of this exercise is to rule out ink tanks that are behaving and isolate the one(s) responsible for the duplicate. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Hope this helps
Mike
on Aug 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
How do you remove the ink cartridges from the
To service the ink tanks:
Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
i_note_us.gif Note
If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2 Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3 Remove the ink tank whose lamp is flashing fast.
(1) Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Important
bullet_s.gif Handle ink tanks carefully to avoid staining clothing or the surrounding area.
bullet_s.gif Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
i_note_us.gif Note
Be sure to replace ink tanks one by one when replacing more than one ink tank.
4 Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
(1) Unpack the new ink tank and completely pull off the orange tape. Then, remove the film.
(2) Remove the orange protective cap from the bottom of the ink tank and discard it.
Important
bullet_s.gif Be sure to remove the clear film from the ink tank in the exact order shown in step 4-(1), as failure to follow this step may cause the ink to leak and stain your clothes and hands.
bullet_s.gif Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
bullet_s.gif Do not re-attach the protective cap once you have removed it.
bullet_s.gif Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
bullet_s.gif Ink on the removed protective cap may stain your clothes and hands.
bullet_s.gif Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5 Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the push_3.gif mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important
Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6 Close the Inner Cover.
i_note_us.gif Note
Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7 Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
i_note_us.gif Note
bullet_s.gif The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
bullet_s.gif To maintain optimal print quality, use an ink tank within six months of first use.
bullet_s.gif Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
bullet_s.gif Color ink consumption may occur even when black-and-white or gray scale printing is specified.
Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
bullet_s.gif When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Apr 03, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
Hi there
For troubleshooting purposes,
Perform the following:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
    <5> Tape remains.
    N
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Getting error 681 "more thn one magenta tank instaleld" on MP530
    <5> Tape remains.
    N
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Ink tank lamp lights not coming on when ink cartridges installed
Remove tape from the ink tank - MP800R / MP830 / MP530
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads. It is necessary to adjust air pressure outside and inside the tank so that ink flows properly. If ink does not come out, check to make sure that the protective film has been correctly removed.
    Caution:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the tab to release the ink tank (1), then remove it from its slot (2).
    Caution:
    a. Do not remove the print head from the machine.
    b. If several ink tanks need replacing, remove and replace each one individually.
  5. Check the ink tank. If the orange tape is as shown in Figure (1), it is properly removed.
  6. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  7. Insert the ink tank diagonally into the print head.
  8. Press it in firmly until it locks into place.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  9. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
  10. Close the inner cover and the scanning unit (printer cover).
    Note:
Dec 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon Bubble Jet i80 InkJet Printer Logo
50 people viewed this question
old marine
old marine
