Question about Gateway 7330GZ Notebook
Laptop screen will not come on
I replaced the lcd and the backlight works great but still no picture on screen. plug in extrenal screen and i have a beautiful picture can you point me in the right direction. thank you very much
  • 201 Answers
Replace the ribbon cable
that is for the picture part
or it may just be loose
Posted on Jul 19, 2009
    Scholar:
  • 77 Answers
Check the connection leads, make sure they are securely fastened to the motherboard, it sounds like there is no communication from the laptop to the screen.
Posted on Mar 12, 2009
  • 211 Answers
Incompatible screen - replace the screen.
Desktop is black
Hi mistopassio...
Try plugging the laptop into an external monitor..
If the picture comes on..replace you lcd screen
If the picture does not come on...replace the lcd and/or you lcd inverter/backlight
Please take time to rate me thumbs up
Sep 12, 2011 | Compaq Presario Notebook
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
When i start my laptop it's screen appears black,processor looks working but no visual at all.what to do?
hi
the screen maybe the issue where you have to replace the LCD panel.. to verify intergrity of the LCD screen operation of this Dell , plug an extrenal monitor to the back of the Dell notebook. If you can view everything clearly on the externalk monitor , then i am sorry to say the LCD panel of the dell notebook must be replaced with new one.
i found same issue on Dell site , someone lese has same issue.
http://en.community.dell.com/support-forums/laptop/f/3518/p/19341026/19729598.aspx#19729598
Jan 09, 2011 | Computers & Internet
The backlight on my laptop went out and i want to know how to go about fixing it, or how much it might cost to have it fixed?
If you don't mind spending under $20 and have a couple of small screwdrivers and 2 hours to kill, it's not too complicated.
To replace the backlight, you'll need to disassemble the entire lid (often you can't get the lid of the laptop off without removing some covers and the keyboard on the main body). Keep those screws separate and labeled (I use an egg carton when I'm working on a new laptop, and often take a few pictures with a digital camera if I have one handy, especially if it has a macros feature for zooming in close).
Once you have the whole screen assembly (the entire lid and screen) off the main body, you'll need to disassemble it, then REMOVE the LCD completely.
NOTE --BEFORE you disassemble the entire LCD (or even somtimes remove if from the frame) to get to the backlight, unplug the current inverter (that long thin circut board with usually a plug at each end) and plug the new backlight into the inverter. Power on the laptop- bulb comes on? Great- you got the right part- it IS the backlight that burnt out!--
So pull the LCD out, then pull the tape and any tiny screws, saving both, and check the bottom area -usually the backlight is under a silver metal "tray" piece on the bottom of the LCD. It's a tiny long flourescent light bulb, with wires at each end.
Pull that out, and replace with the new one.
BEFORE you reassemble, plug the inverter in again (the little circut board you found in the LCD lid) and power the laptop on for a moment- after a few seconds you SHOULD see the bulb light up! Keep checking briefly as you assemble the laptop again- making sure you have everything plugged in correctly BEFORE you get all those screws back and tightened down!
Usually to have a shop do it can cost as much as a new LCD on Ebay -at least $60~120 USD. A backlight is about $15 and a new inverter maybe a bit less on ebay.
:D
Sep 04, 2010 | Computers & Internet
My Compaq CQ60 displays on ext. VGA but not on board.
Switch the Wireharness from the old LCD to the new one, If you look carefully they do come off.
Apr 12, 2010 | Computers & Internet
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
When I start up my laptop, the screen is black.
You could have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 07, 2009 | Computers & Internet
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Gateway 7330GZ Notebook Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
