Question about HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer
Hp 0x6101bed - HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer
My HP 6500A plus is giving an error code 0.6101 bed. Do you know what the problem is, is it practical to repair.
Do you mean the error 0x6101bed? This appears to be an error with the printer carriage or the sensors that detect paper in the trays. Unplug the USB cable if you are using that connection before trying the steps below.
Some people have solved the problem by turning off the printer and then removing the photo feed and output trays. Also remove any extras like a duplexer if you have one. Put in a sheet of plain paper. Then turn on the printer and quickly press the Menu button. Find the menu item for printer reports and select print status report (or a similar item). Push the paper gently into the printer pickup until the pickup spool catches the paper. Press Cancel and see if the printer ejects the sheet.
Some people have found that adding a few extra power on/off power cycles (5-6) helps. Then try to to move the print cartridges (gently - do not force anything) while the printer is off. While you are trying to move the print cartridges, check for any foreign objects in the printer. (A small piece of paper can cause the bed error.)
Make sure that the printer is on a firm surface wider than the printer. Pick it up and put it down again to shake things loose inside. At some point, the printer will go into a initialization step if you have solved the internal issue.
If these don't help, it may be that the internal frame and the rail that the printer cartridges ride on is bent. Then the solution is probably to replace the printer.
I hope this helps.
Oct 21, 2014 | HP Officejet 6500A Plus Wireless...
Screen instructions
Here's a place to start. Go into Control Panel, Programs and Features, and look at each program that starts with "HP". Look up each one on the web and see if they are bloatware, and remove those that are.
If they exist, I uninstall the following... HP Customer Participation Program, Shop for HP Supplies, HP Registration Service, HP Customer Feedback, HP Product Assistant, HP OrderReminder, HP Quick Launch, HP Launch Box, HP Wallpaper, HP Performance Advisor, HP Easy Backup, HP Power Assistant, HP Image Zone Express.
See... http://www.shouldiremoveit.com/HP-oem-bloatware.aspx
There are often many more, but you should research them.
Jul 16, 2014 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
Pontiac engine codes
1964 - 1979 Pontiac Engine Codes Bold Type is for manual transmissionStarting in '73,2nd HP # is for Dual Exhaust 1964 326 250 HP 92x,96-0 326 280 HP 94x,97-0 389 230 HP 04L,05L,08R,09R 389 235 HP 22B 389 267 HP 389 283 HP 10A 389 303 HP 25K,26K,27P,28P 389 306 23B,29N 389 325 78X,79J 389 330 32B,34N,33-6 389 348 76X,77J 421 320 35B,38S,43N 421 350 44B,47S,49N 1965 326 250 WP,ZN 326 285 WR,YP 389 256 WA,WB,YA,YB 389 290 WC,YC,YD 389 325 YE,YF 389 333 WE 389 335 WT,YS 389 338 WF,YG 389 360 WS,YR 421 338 HP WG,YH 421 356 WH,YJ 421 376 WJ,YK 1966 326 250 WP,WX,YN,XF 326 285 WR,YP,XG 389 256 WA,WB,YA 389 290 WC,YV,YU,YC,YD 389 325 YX,YL,YW,YF,YE 389 333 WE 389 335 WW,WT,YS,XE 389 360 WV,WS,XS,YR 1967 326 250 HP WP,WX,WC,WH 326 250 HP YO,YN,XF,YJ,XI 326 285 HP WR,XR,WK,WD 326 285 HP YP,XG,YM,XO 400 255 HP XL,XM 400 260 HP 400 265 HP WA,WB 400 265 HP YA,YB,YC,YD 400 290 HP XV,XU 400 293 HP XC 400 325 HP WU,WZ,WQ,WI 400 325 HP YE,YF,YT,XE,XN,XW,XX 400 333 HP WD,WE,WY,XT 400 335 HP WT,WW,YS 400 350 HP XZ,XY,XH,XJ 400 360 HP WS,WV,WR,XS,YZ,XP 428 360 HP WG,Y2,YY 428 376 HP WJ,XK,Y3,YH,Yk 1968 350 265 HP WD,WC,YN,YJ 350 320 HP WR,WK,YP,YM 400 265 HP XM,YA 400 290 HP WA,WB,YC 400 330 HP 400 335 HP WQ,WZ,WI,XN 400 340 HP WU,XT 400 350 HP XZ,XH,YS,YZ 400 360 HP WT,WS,XS,XP 400 366 HP WY,XW 428 375 HP WG,YH 428 390 HP WJ,YK 1969 350 265 HP WC,WP,WM,WU 350 265 HP XL,YJ,XR,YN,XB,YE,YU,XS 350 325 HP WK,WN,XC,XD 350 330 HP WR,WV,XT,XU,YP 400 265 HP XM,YZ,XX,YB,YF 400 290 HP WA,WB,WD,WE,YC,YD 400 330 HP WZ,YT 400 335 HP WQ,YW 400 340 HP 400 345 HP WH,XN 400 350 HP WT,WX,YS,XH 400 366 HP WS,YZ 400 370 HP WW,XP 400 375 HP WI,WY,XY,XW 428 360 HP WG,YL,YH,XE,XJ 428 370 HP WF,XF 428 390 HP WJ,WL,YK,XG 1970 350 255 HP W7,WU,X7,YU 400 265 HP 400 290 HP WE,YD 400 330 HP 400 350 HP WX,WT,XH,YS 400 366 WS,YZ 400 370 WW,WH,XP,XN 455 360 HP WA,YC,YH 455 370 HP WG,XF 1971 350 250 HP WR,WU,WN,WP 350 250 HP XR,YU,YN,YP 400 265 HP WS,WX,XX,YX 400 300 HP WK,WT,YS 455 280 HP WG,YG 455 325 HP WJ,YC 455 335 HP WL,WC,YE 1972 350 160 HP WR,YU,YV,YR 400 200 HP YX,YZ,ZR,ZV,ZX 400 250 HP WK,WS,YS,YT,ZS 455 200 HP 455 220 HP YA,YC,Y4 455 300 WD,WM,YB,YE 1973 350 150,175 HP XR,WV,ZB,ZD 350 150,175 HP Y2,Y7,YR,YV,ZR,ZV 350 150,175 HP WA,WC,WD,WF,WL,WN,XZ 400 170,185 HP W5,XH,XI,X3,X4 400 170,185 HP YI,YP,YX,YZ,Y4,ZK,ZX 400 200,230 HP WK,WS,WP,YN,YX,YT 400 200,230 HP Y3,ZN,ZS,XK,XN,XX 400 200,230 HP XZ,X5,YF,YG,Y6 455 215,250 HP WT,WW,ZZ,ZE,YA,YC 455 215,250 HP YD,YK,ZA,AC,XA,XE,XJ 455 215,250 HP XL,XY,XT,X7,XO,YE 455 290 ZJ,XD 455 310 Z8,X8 1974 350 155,170 HP WA,WB,AA,YA,ZA 350 155,170 HP YB,YC,ZB,YN,YP,YS 350 170,200 HP WN,WP,ZP,YN,YP,YS 400 175,190 HP AH,YH,YJ,ZH,ZJ 400 175,190 HP AD,YF,YK,ZD,ZK 400 200,225 HP WT,WR,Y3,AT,YT 400 200,225 HP YZ,ZT,AD,YL,YM,ZS 455 215,250 HP AU,YR,YU,YW,YX 455 215,250 HP YY,ZU,ZW,ZX,A4 455 215,250 HP 455 290 HP W8,Y8 1975 350 155 HP YB,YA 350 175 HP WN,YN,ZP 400 170 HP 400 185 HP WT,YS,YT,ZT,YM 455 200 HP WX,YU,YW,ZU,ZW 1976 350 160 HP (Early) YB,YA,YP,YR,ZX 350 160 HP (Late) XM,XP,XU,XR,XW,XX,X3,ZF,ZH 350 165 HP 400 170 HP (Early) YJ,YC 400 170 HP (Late) X9,X4,XT,XY,XS,XZ,X8 400 185 HP (Early) WT,Y6,Y7,YS,YT,YY,YZ,ZA,ZK 400 185 HP (Late) WY,X7,ZJ,ZL,X6 455 200 HP WX,Y3,Y4,Z3,Z4,Y8,ZB 1977 301 135 HP WB,YW,YX,YH,YK 350 170 HP YA,YB,XB,XC,Y9 400 180 HP 400 180 HP YU,Y4,XA,Y7,XK 400 200 HP WA,Y6 1978 301 140 HP XA,XC,XL,YM 301 140 HP XD,XB,YL,YP 301 150 HP XF,XH,XU,XW 400 180 HP XJ,XK,X9,YK,YH,YS 400 180 HP YT,YJ,YR,YW,YA,YU 400 220 HP WC,X7 1979 301 135 HP PX7,PX9,PXF 301 135 HP PXH,PXP,PXR 301 150 HP PWA,PWB 301 150 HP PX4,PX6,PXL,PXN 301 150 HP PXS,PXT,PXU,PXW 400 220 HP PWH,LAST 400
Dec 21, 2013 | Cars & Trucks
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
None of my USB ports are working. I think it's a
We are HP Printer Tech Support Team. HP printer tech support, can save your valuable time, when you spend your lots of time to repair your printer problems. SysTechConnect is one of the HP printer customer support providers which only believe in more than satisfaction of users by its better online support. You can also save your service cost by keeping get in touch with this cost-effective support. Contact us anytime. We are available 24*7.
Website: http://www.printersupportcontact.com/hp-printer
Sep 27, 2009 | HP Pavilion dv5000t Notebook
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
