Question about Maytag Washing Machines
Maytag machine hums but wont do anything
    President:
  • Maytag Master
  • 662 Answers
Locate your motor after taking the plug off the wall mains. Something should be clogging your motor......
Posted on Apr 24, 2013
My washer is making a humming noise and will not run. there are currently clothes and water in the washer
remove 4 screws on the rear panel and then remove the cover, you can see the drain pump remove both hoses on the pump,it is probably plugged up,if it is they wont drain or do anything
Apr 30, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Wont fill when it goes to rinse cycle just sits and hums
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 01, 2010 | Kenmore 15864/15862 Top Load Washer
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Hum's when I pull the knob out but nothing happens
I would check the pump for something small that is jamming it sometimes.
Apr 25, 2009 | Maytag LAT3600A Top Load Washer
Motor Hums on Top Load Maytag Washer
Hi, this is gil1714 in Scotland. Motor not starting properly, and humming. this machine has an induction
motor which has a starter capacitor on the side(the cylinder shaped object). these age out, so try replacing
with one of the same rating (printed on it ??mu). if that doesn't solve the problem, check to see if anything
is partially jamming the drum, or if the machine is overloaded . the other possibility is that the coils in the
motor are starting to fail, which would entail replacing the complete motor. hope this is useful gil.
Dec 17, 2008 | Washing Machines
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytage Neptune Model #MH5500BWW will not drain
I removed the pump and removed thread from a rug that had been washed the day before. The thread had bound up the pump preventing it from turning. Once the thread was removed and the parts put back together the machine worked perfectly.
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine wont fill
the humming noise is usually the inlet valve energised but no water there to come in. i appreciate you have checked. the other possibility is that the appliance has not pumped out completely and the noise you hear is the drain pump energised but stuck due to perhaps a foreign object in it. fault is unlikely to be inlet valve
Apr 01, 2007 | Maytag Atlantis MAV8551 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
