Question about Garden
Ryobi 970r fuel line diagram
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
SOURCE: RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Posted on Jun 27, 2009
canbruce75
  • 1776 Answers
SOURCE: need a diagram on how to connect the fuel lines
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Oct 01, 2009
panilling9
  • 284 Answers
SOURCE: fuel lines
line from the tank with the filter on it goes to the bottom inlet or( depicted inlet) on the carb the top is the return line that goes to the inlet of the primer the other side of primer goes to tank.Primer draws fuel thru carb to tank
If primer is mounted on carb filter line = inlet to bottom fitting= other is return to tank
Posted on May 29, 2010
  • 351 Answers
SOURCE: need a repair manual for a Ryobi 790r
Here is a page that will take you to a download of the exploded view of the trimmer ..
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/790R-SERIALS-810046371-THRU
on the right side there is a place to select the download .
Posted on Jun 02, 2010
Ryobi ry30140 fuel line diagram
Go to web site or try a google search.
Sep 10, 2017 | Ryobi Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 970r
Hey Chris,
If you give me make, model and serial number I may be able to find a diagram for you.
Sep 23, 2013 | Garden
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
I need a diagram for the fuel lines on a ryobi 31cc trimmer plus 15" from the fuel tank thru the primmer bulb to the carb for both lines
Don't quite understand your dilemma... there are only two fuel lines which go from the tank to the carburetor.....if looking at the engine from the back, the fuel line on the left is the intake line and the one on the right is the fuel return line....on the back of the carb are two fuel line brass inserts...they are inlet on left and return on the right....hope this helps ;-D
Jul 15, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Apr 11, 2009 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
