Question about Electrolux 6080 Sanitaire Model SC6080 Commercial Carpet Extractor w/ 9 Gal Tank
Electrolux carpet cleaner
When sucking up water from the capet, water is coming out of bottom of machine ( through the other end of the vac motor ). This is happening when the tank is not even half way full. I have taken the top of the machine off and all parts are connected.
SOURCE: Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
SOURCE: I have a electrolux 2101
Press the lever at the bottom right with your foot to release the handle, then tilt the handle back at the same time - tilting the handle turns it on.
Posted on Nov 18, 2008
  • 109 Answers
SOURCE: electrolux EW1045F, water filling stops at half level, not full
The pressure tube from the bowl could be obstructed. You will have to remove the tueb from the pressure switch and blow through it to see if it's not blocked firstly.
Posted on Jun 16, 2009
  • 70 Answers
SOURCE: My electrolux vac shut off for a full bag. After
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
Posted on Nov 07, 2009
jse2005
  • 103 Answers
SOURCE: electrolux vacuum cleaner 1500W motor diagram
if motor is turning than it's not the motor......check for other more than likely faults such as.......restricted or kinked hoses......obstructed hoses,......clogged vents both intake and output sides.......clogged heppa filters on the output side...after the motor if it has one......restricted or obstructed intake air vents where the motor sucks air in........clogged bags if it uses bags.....in any case, you have something either blocking or restricting the suction side or something restricting the air output side.........if all is well and you see no blockages, then and only then should you suspect the motor.
Posted on Nov 27, 2009
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Why does my steamvac not suction the water up?
Typically there is a little red filter accessible from the bottom of the cleaner. Lay it down and flip it over to take a look. It's a little screen like filter. Large particles than can possibly cause a clog are filtered out there. Just pull it out (it will only come out part way) and clean the debris from it.
I have a Hoover Steam Vac also. Learned that trick the hard way. If that's not the problem (it usually is) then I will need the model number from your machine. Hopefully they didn't put it on the bottom of the machine where the numbers wear off. That's where mine was.
Zashiban
Jun 24, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Pro hEat will not **** up water from carpet
check the vac motor hose could be clogged? does the vacuum motor turn on? check the vac motor on switch for power using an ohms meter.could have a bad vacuum motor or micro switch.
Jan 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Joe
Nov 19, 2009 | Electrolux Vacuums
Is not sucking. Water comes out fine, but when the trigger is released, the water does not get sucked back.
Without more input from you, it is difficult to know what the problem is. Do you hear the vac motor wining ? If so, then ther is a clog in the passage or there is damage to the vac motor/impellor blade. If no sound from vac motor, well of course it will never ****-up the water. YOU WILL NEED TO TAKE IT TO A GOOD HANDY MAN OR AN APPLIANCE REPAIR/VAC REPAIR CENTER. Good luck, Macgivor
Oct 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Solution tank does not dispense--recovery tank still sucks up dirty water from tile floor on screen porch. I applied cleaner manually with a scrub brush and sucked it up with the hoover steam vac deluxe.
Check to see if the when you squeeze the trigger, the rod is hitting the reservior asm(tank sits on). If not then there is a problem inside the handle and the rod. If it is hitting, then the reservior asm. is bad. Also make sure fluid is coming out of the tank when you push the vavle in at the bottom of the tank.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Electrolux 6080 Sanitaire Model SC6080 Commercial Carpet Extractor w/ 9 Gal Tank Logo
26 people viewed this question
Top Electrolux Tools & Hardware - Others Experts
Are you an Electrolux Tool and Hardware - Other Expert? Answer questions, earn points and help others
