Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
My craftsman 42 in. 22HP is "scalping" areas in my yard I have the height adjustment on 5?????
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Posted on Nov 03, 2009
aquaman987
  • 927 Answers
SOURCE: the deck on my mower is lower on one side than the
To adjust a Craftsman deck, raise the deck to the normal cutting height.
Measure to the flange on the deck on the right & left sides. It is easier to lower the deck than to raise it, so, on the high side, find the threaded rod that supports the deck. Using a wrench, back off of the nut (counterclockwise as viewed from the end of the rod) until both the left & right sides of the deck are the same height.
Be sure your tires are properly inflated before measuring.
Gary
Posted on Jul 03, 2011
SOURCE: 2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Posted on Jul 29, 2011
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Mtd yard machine 46" scalping lawn at highest setting
Try setting in the extreme opposite direction. If that does not do it then the adjuster is stuck in the lowest position. Check your manual.
Jul 11, 2015 | Mtd Garden
Craftsman riding mower 17hsp. older model,how to adjust mower deck, it scalps my lawn.
which one,there are a few ways to adjust it,1,there is a knob on the side by your foot with a gauge in inches,turn that to raise it to the desired height,with your release lever down,that is where you want to check for height,if that doesnt work,pick deck all the way up,unbolt each wheel and drop them down to the bottom hole,try that,if it still isnt right,there are 2 bars on the front of the deck,they should be in the middle holes,you can tighten them a little,but,that will affect the drive belt,dont play with those unless the nose is too low,if none of that works,there are 2 bars that clip tp the deck and hang on 2 bolts it is the lift system,you can tighten the bolts on those to lift the deck also.if i knew the number i would be able to have pics and diagrams for you,i believe it is, Craftsman 917.27318
Jun 02, 2015 | Craftsman Garden
When turnig three sixty my mower scalps yard
Check air preasure in your tires. It should be about 12-15 psi. GOOD LUCK FRIEND.
Sep 18, 2014 | Garden
Cutting deck too low
do you have anti scalping wheels installed and working properly?these are a safe guard features. There should be a threaded ready rod and lock nut or turn buckle assembly that can be used to adjust mower deck height.
Aug 16, 2014 | Garden
Mower deck adjustment
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The deck on my mower is lower on one side than the other. Is there a way to raise it up? It is tearing my yard up and scalping. I have a craftsman 15hp 42inch cut command. Any help would be appreciated...
Gary
Jul 03, 2011 | Craftsman Garden
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Hower do you do the adjusting for height on the
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
