Question about Air Tools & Compressors
Dust shield installation
How to install opitional dust shield for bositich framing nailer f28ww
    New Friend:
  • 131 Answers
Attach to nose bolts on side of magazine. Did it come with washers?
Thanks,
Jeff
Posted on Jun 30, 2009
My bostitch GBT1850 (new) only fires 5 percent of the time
O-ring is most likely broken or damaged. Replace it and lube the cylinder good with gun oil or MMO
May 30, 2014 | Stanley Bostitch Stick Framing Nailer...
N88rh bostitch nailer fires first shot without trigger depressing
Worn orings in the gun and the trigger valve will cause the gun to fire upon connecting the air. It is a good practice to remove the nails when you remove the airline until you can replace the trigger valve. I believe that you gun uses a TVA6 valve. It should be replaced when it begins to leak or if the trigger pin seems loose and rocks from side to side. Factory valve costs about 25 dollars and aftermarket sells for about 12 to 18 dollars. Good luck
Jan 20, 2014 | Stanley Bostitch 28 Industrial Framing...
F28WW-fire gun. piston doesn't retract back, trigger is good gun is clean & oiled what could be the problem. nailer year old
Check band # 175520 (black rubber band around the outside of the cylinder) is what causes the piston to retract. If the check band is in place, then problem could be caused by cracked lower bumper, worn piston oring or cylinder seal on the headvalve. IF the cylinder seal is bad, air will leak between seal and the top of the cylinder and could push piston down cylinder. If piston oring is too loose, the piston will not stay at the top of the cylinder. If you point the nose of the gun up then down again and the driver moves within the cylinder, replace the oring. Good luck
Apr 04, 2013 | Stanley Bostitch Stick Framing Nailer...
I have a Bostich f28ww. It wont fire. When you pull the trigger, it only lets out air
The seals have gone bad you will have to replace the seals in it. Try tightening the nuts on top of it
Mar 02, 2011 | Stanley Proto Stanley Bostitch F28WW 28...
Leaks air around the trigger. Doesn't shoot the nails at 100psi, I think it is a F28WW Bostitch shoots the 2'' and 31/2'' nails
sounds like the trigger valve has a broken o ring and would need replaced. you can go to Bostitch.com and order one for it, they are not that hard to install.
Jan 16, 2010 | Stanley Air Tools & Compressors
THE AIR IS PASSING THROUGH THE GUN OUT THE TOP
you have a bad seal and need a rebuld get a kit from your local supplier
Oct 07, 2009 | Stanley Bostitch 28 Industrial Framing...
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Air Tools & Compressors Logo
50 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
