Question about Audiovox Xm Onyx Sirius Xm Satellite Radio Tuner
Help Audiovox Onyx
My radio drops a signal easily anytime I am in a city with tall buildings. I've placed my antenna in many places and nothing helps. My crappy little old radio worked everywhere, even in the parking agarage at work. What is the deal? Help. I've also tried two different types of antennas.
    Genius:
  • 1,144 Answers
Its because of the tall buildings and all the power around you breaking the signals.
Posted on May 06, 2013
Digital Lifestyles TV. No Signal
you need either a cable ,satellite, or antenna for an input to get any pictures from any place .
Aug 24, 2016 | Digital Lifestyle Televison & Video
How do I know which direction to point my TV antenna?
Well TV transmitter stations are usually located on top of high hills or really tall buildings. So you want to point your antenna towards something tall. If you live in a largely flat area just face it straight up.
Jan 31, 2013 | Electronics - Others
Which router modem is best ?
If you get a wireless-N router, and you have a wireless-N adapter on your computer, then it should work...depending on the physical environment and building type. If the building has steel-beam construction, or log walls for example, then this will inhibit the wireless signal drastically. Also, having a clear line of sight between the router and intended coverage area will help. Trees and tall brush can also kill the signal. Try to place the router closest to the area you want to cover, so the signal doesn't have to pass through several walls. Try placing it on a window ledge facing the area to be covered. If all else fails, there are high-powered N routers available, signal amplifiers and larger antennas for the router, and also consider mounting an antenna outside. Start with an N router and an N adapter for the computer first though as this is the least expensive solution, and may do the trick.
Hope this helps!
Joe
Apr 16, 2012 | NetGear WGR614 Wireless Router
What is wrong with a satellite reciever when all I am getting is aquiring signal displayed
This indicates that the antenna is not gathering enough of the signal to be played. This can be caused by an obstruction between the antenna and the satellite in the sky ie: tall buildings, heavy tree cover, covered garage, etc. It can also indicate a problem with the antenna itself, the cable between the antenna and the radio, the connector on the end of the cable or in the radio or, a problem with the antenna circuit inside the radio.
Since there's little you can do about the last item in the list, check the other parts of the antenna for damage. A pinched or crushed cable will short out the antenna signal - and the voltage sent to it by the radio. If allowed to persist for very long, damage to the radio could result. Look for breaks in the outer jacket of the cable - water entering the cable will cause corrosion and will degrade the signal, too. If you find a problem with any part of the antenna system, about the only thing you can do is replace the antenna completely. You can get a replacement online for as little as $9 and change.
Before installing, try connecting the antenna to the radio with the antenna exposed to ta clear view of the sky in a location that you were able to receive a signal before. If it works, you're done. If it doesn't - the problem is internal to the radio and will need to be repaired - or replaced.
I hope this was helpful - if it was - please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Sirius Radio Receiver
I just purchased two radios. How far will they transmit and receive with good clarity in the city? I need to transmit and receive from about six to eight miles away clearly. Thanks.
bobengelman,
Typically and unmodified handheld CB will have a decent talk distance of 1-2 miles with both being a handheld. Further distances can be had if one of the radios was a mobile or base station with distances of more than five miles with weak signals. In some cases the antenna can be changed to a better longer antenna. Extention type antennas typically transmit about a mile per watt. Conditions such as terrain will have an impact on signal specifically mountains or buildings. Better results may also be had by purchasing a mobile magnet mount with a PL-259 to BNC to fit the radio. A magnet mount placed on a air conditioning unit or large cookiesheet as high as possible will make decent gains for distance if the radios are intended to be stationary.
JT Radiojunkie
Jun 21, 2010 | Midland 75-785 Handheld CB Radio
My new TomTom One XL will not pick up a GPS signal.
Well, it MAY help to download the tomtomhome program from the tomtom website, then connect your unit to your computer and update, including the gpsfix application (that's for all the other posters who didn't mention having updated). But for Drakeca05, updating MAY have been what messed you up in the first place. I updated two days ago with tomtomhome--my tomtom one was working fine, but was a little slow to initially acquire satellites. Now since the update it's even slower, sometimes won't acquire them at all, and randomly drops them. Tomtom tech assistance is useless--they just refer you to the standard "acquiring satellites" faq that you can easily find yourself on their site & nothing there is the least bit helpful for this.
Dec 28, 2008 | Tomtom ONE 3rd Edition GPS
GPS looses direction in city streets
If you are driving in a city with a lot of tall buildings, trees or elevated trains, the unit will lose the signal from the satellites. This is due to the GPS receiver used on the C340. It may help to place the unit in WAAS (Wide Area Augmentation System) mode. This uses ground information as well as satellites to help you navigate. Good luck.
Apr 10, 2008 | Garmin StreetPilot c340 GPS Receiver
No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Jul 30, 2007 | Audiovox XCS9 XM Radio Receiver
Where should I place my router?
This describes moving equipment, positioning antennas, and avoiding obstacles. When optimizing your existing equipment, consider: * Placing antennas in a good location, at a good angle. * Avoiding physical things that block signals. * Reducing the interference from other things that transmit radio waves. Before starting adjustment, make sure that antennas and cables are securely fastened! If your network has more than a couple wireless devices, before you move things, decide which wireless devices are transmitting the heaviest load. These links are important to optimize. NETGEAR products have automatic data rate fallback, which allows increased distances without losing connectivity. It also means that devices that are further away are inherently slower. Therefore the most critical links in your network are those where the traffic is high, and the distances are great. Optimize those, first. The ones that are least important are links that have little, occasional traffic, and which have a strong signal strength. Picking Good Locations for Antennas * Antennas should be in line-of-sight of one another, where possible. Put your face next to one antenna, to find whether the other is visible. * Place high, and clear of obstructions as practical. * Keep antennas 2 feet from metal fixtures such as sprinklers, pipes, metal ceiling, reinforced concrete, metal partitions. (However, antennas on roofs do not necessarily give the best results. ) * Keep away from large amounts of water such as fish tanks and water coolers. * Antennas transmit weakly at the base, where they connect. So don't expect good reception from the bottom of a router or access point. * For multi-story buildings, placing antennas at 45 degrees (diagonally) or 0 degrees (straight out parallel to the floor) may be most effective. Reducing Interference Avoid windows unless communicating between buildings. (Windows let in interference from the outside world.) Place antennas away from various electromagnetic noise sources, especially those in the 2400 ? 2500 MHz frequency band. Common noise-creating sources are: * Computers and fax machines (place wireless equipment no closer than 1 foot) * Copying machines, elevators and cell phones (no closer than 6 feet) * Microwave ovens (no closer than 10 feet)
Feb 19, 2006 | NetGear RP114 Router
Audiovox Xm Onyx Sirius Xm Satellite Radio Tuner Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
