Question about Husqvarna Sewing Machines
Bobbin my bobbin wont' work...it's been cleaned and the needle changed....still won't work
  • Husqvarna Master
  • 7,365 Answers
Try turning the bobbin the opposite direction and see if that helps, if it doesn't help then the machine may need to be checked.
Posted on Apr 24, 2013
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
SOURCE: Needle wont catch thread on bobbin for sewing or
Perhaps spool in bobbin case backwards, or thread not in bobbin thread guide on bobbin case...
Posted on Mar 05, 2010
  • 1788 Answers
SOURCE: Needle won't pick up bobbin thread. Has been
Most of the time it is because the needle was inserted with the flat side facing you instead of away from you. And for the heck of it, put in a different needle, there may have been a burr or some defect on your new needle. Other than that, it could be your timing.
Posted on Apr 04, 2011
  • 415 Answers
SOURCE: All of a sudden the needle won't pick up the
Check the tension. Make sure the bobbin tension isn't too tight and/or that the top tension isn't too loose. If the bobbin tension is too tight it won't be able to be drawn up and make the stitch. If the top tension isn't tight enough it also won't be able to draw the thread up. They need to be balanced to work together.
Test the bobbin tension by dangling the bobbin (in the casing) by the thread and give a slight flick of your wrist. It should drop down a bit as the thread is released. If it hits the floor it is too loose btw. If it doesn't drop a bit without great yanking it is too tight.
Then check your top tension and make sure there's a bit of resistance when you pull on the thread.
If you're having a lot of problems first try sewing on a plain cotton material and examine the stitch when set to a wide zig zag. When you get it adjusted so it sews that correctly then go back to what you were sewing on and make sure you have the right size and type of needle and that it is inserted correctly.
One of those things should correct the problem.
Posted on Jun 11, 2011
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Posted on Jul 31, 2011
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
I have a Hyundai 60 stitch sewing machine, the needle snapped so I replaced it now it won't stitch! I have changed bobbin, tension, tried different stitches but it still won't stitch! It's...
Take the needle out and put it back in carefully. If that doesn't solve the prob, replace it with another needle, and hopefully it will return to working.
Sep 24, 2012 | Sewing Machines
Clanking noise & won't sew
Are you sure you put the correct type of needle in? Normally, if you have any problem, cleaning and oiling will fix it. It sounds like you either didn't tighten the needle screw or you put the wrong type of needle in.
Jun 24, 2012 | Janome Sewing Machines
Needle won't catch bobbin thread
try changing the needle-flat side goes to the back of the machine
clean under the needle plate & in the bobbin area for loose threads or lint
Apr 07, 2012 | Singer 8280 Mechanical Sewing Machine
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Why won't the bobbin thread pick up?
have you tried changing the needle? if it's a new needle is it inserted correctly---flat side to the back of the machine---needle push up in inside the needle holder
have you tried cleaning under the needle plate & in the bobbin area for lint or loose threads?
have you checked the bobbin to make sure it's not warped
have you checked the bobbin is inserted correctly?
if you've already tried these things then the last thing that possible is the machine is out of time & needs to be serviced by a repair shop that have the correct tool to time it
Aug 29, 2011 | Brother XL-2600
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
I have a singer inspiration4212 and I was sewing and a piece of materialwent down into the feed dogs and I had to tug a bit to get it out.Now my bobbin won't pick up the thread. I have taken the bobbin...
even if the needle is not bent, the needle could have a burr on the tip, I would try a new needle
clean under the needle plate & in the bobbin area for loose thread or lint
if the machine still does not work then it could be out of time
Aug 02, 2011 | Sewing Machines
Brother pe 150 needle wont pick up thread from bobbin changed needle
Check that the needle is in the right way, flat shank to the back. If it is around backwards, the shuttle hook won't be catching the thread at the back of the needle to form the stitch.
Jun 22, 2011 | White Sewing White 3032
Sewing Machines Logo
20 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
