Question about Insignia 39 in. Class LCD HDTV
Can't get composite to work
I have an insignia 39" LCD TV and it is not recognizing my PS2's composite cables. I have correctly put the red, yellow, and white colored parts into their respective locations, but the insignia tv is not recognizing anything new when I turn on my PS2. I looked through every channel and input the Insignia had and looked around my settings page and still nothing. Is it a lost cause?
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
ripleymojica
  • 643 Answers
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Posted on Jul 02, 2009
  • 15 Answers
SOURCE: tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Posted on Sep 12, 2009
SOURCE: Ideal Insignia 42" LCD 1080p Color settings
color settings for tv 42 in"
Posted on Sep 20, 2010
I can't get the sound to work from my tv to my dvd/vcr player. i have it plugged into the right spots on the tv & dvd/vcr player stil no sound
Tries another set of cable,some time the cable have bad shorted at the cable neck flexable and not working correctly are the causes.Ur DVD/VCR player have a HDMI hub connection,used a HDMI cable for connection will work better for a HDTV.
Jun 09, 2011 | Insignia 42" LCD Flat-Panel HDTV
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We cant get our wii to work on a new 32 insignia lcd hd flat screen. Not sure what to pick under input selections.
If you didn't purchase the COmponent connector, set your TV to look at the A/V input. Composite cable is what comes standard with the Wii (yellow is video, red and white are audio).
As long as the Wii is connected to your TV correctly (cable color matches input color, and there are no other devices on a shared input...i.e. HDMI + Composite in on Input 4) you shouldn't have a problem.
Hope this helps!
Feb 15, 2010 | Insignia IS-LCDTV32 32 in. Television
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Insignia ns-lcd32-09 wont play VHS
Yes, that is correct you need composite (or coax) cabling to your TV. The unit cannot carry the VHS signal via component video or digital audio cabling
Feb 27, 2009 | Insignia IS-LCDTV32 32 in. Television
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
Insignia 39 in. Class LCD HDTV Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
