Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I was vacuuming with the Dyson DC 17 and sucked up a berber carpet string by accident and after cutting and pulling it all out of the bottom brush part, the brush no longer spins but the suction part works. What do I do?
  • 328 Answers
The belt could be snapped. If this model has a brush protected belt then it has to be repaired by a service call. If however you can get to the brush roll belt by removing the bottom sole plate (turning over the vacuum so that you're looking at the base) with the plastic catches undone where you can see the belt then check to see if it has snapped. If it hasn't snapped then it may just need readjusting.
If you can't see the belt and has protective covers that can't be undone then the model has a brush control system that has to be replaced by someone who can do Dyson repairs.
Posted on Mar 13, 2009
Squeeling noise dyson 33
Is it when you go from carpet to floor or floor to carpet? It will make a loud noise detecting a possible suction issue. I've also had loud noises and turned over the vacuum and where the brush is, traps hair, thread, rubber bands, etc. Just take a scissor and cut it all out. Don't cut the bristles. Roll the brush as you cut and pull all the stuff wrapped around the brush. Once it is free, try it again.
Jul 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
Dyson dc 17 vacuum. brush not moving
The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
Apr 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brushes wont turn,but it has good suction for the hose
you have to remove the bottom cover to inspect the belt. Usually if the brush is jammed, you will smell an odor similar to burning rubber. In the absence of that smell, its likely the belt. Its easy to replace
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
The handle to a canvas bag got stuck in my DC 17 animal Dyson and now the brush won't turn.
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet
got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with
the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin,
press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner
and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
Apr 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
DC 17 Beater Brush won't turn
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Jan 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
252 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
