Question about Birds
Repair concrete bird bath - Birds
How to get rid of lice on small birds
No idea of your country but a 20Second google search revealed this;
To remove lice, it is recommended to use a mild pet insecticide, such as "Nuvan." After spraying the plumage, wait for 2 - 3 minutes and then gently ruffle the feathers over a white tray or plastic sheet to collect the lice which fall from the feathers.
I found that one great way to remove lice and mites from your birds is to sprinkle Sevin Garden dust under their wings and tail, and on the back. Check the birds the next day and if there are still lice present, repeat the process, as needed. I found Sevin dust [active ingredient: Carbaryl (1-napthyl N-methylcarbamate)] equally effective in getting rid of red mites.
Avian Insect Liquidator is another way to get rid of mites, lice and other insects in the birds' environment. This all-purpose insecticide from Vetafarm contains a water-based insecticide that is harmless to birds but effective against insects.
Prevention:
Sanitize and treat the birds' environment (cages, perches, aviaries, nesting areas, etc.). Secondly, allow your birds to bathe daily. Most birds enjoy doing so and if you provide them with a shallow clean dish, they will usually be happy to bathe without encouragement. Some birds like to be misted, or even sprayed. Sprinkling Sevin dust underneath nest bowls and around nests will eliminate all kinds of insects.
Aug 06, 2017 | Birds
Is there a direction finder for birds?
Do you mean something like a bat detector ? Not that I know of - when I attempt bird photography, I tend to wait in what I hope is a likely spot and look for movement. Alternatively, find somewhere birds feed or bathe and try to take photos there.
Good luck
Feb 24, 2017 | SPOT Cameras
I had a bird about the size of a robin but with a shiny black body and a brown head visit my bird bath this morning. Any idea what it might be?
Try Petersons field guide. Theyre great books on birds ,plants, wildlife, and fish among other things.
Apr 18, 2016 | Cars & Trucks
What is a grooming perch?
This is a type of perch for your bird cage that allows for some self-grooming. It is a great way to trim down your bird's nails. They often come in great space-saving styles such as corner perches and half sizes. Look into concrete-blended perches. In my opinion they are the best type of grooming perches. Here are a few examples -
http://www.perchfactory.com/bird_cage_perches/sandy_cement_perches.htm
http://www.avianenrichment.com/store/pc/Grooming-Perches-c133.htm
Aug 30, 2012 | Allied Precision Birds
How do I bathe my parakeet?
Birds tend to groom themselves. But sometimes they can fall behind and startto smell a bit. If you insist on bathingyour parakeet, I don't recommend doing it more than once a month. It is easy do to as long as you follow these guidelines:-Use fresh, clear water. Do not use Shampoos or conditioners-Wash your bird around the warmest time of day-Wash your bird in lukewarm water - not to cold and not toowarm-Don't saturate the bird's feathers
May 15, 2012 | Pets - Others
Removing chicken feather commercially without human inthe process?
This generally involves the use of a "plucking machine". After the chicken runs through the kill line, it is submerged into a hot bath of water in order to losten the feathers. The bird is then taken through a plucking machine which has rows of rubber "fingers" spinning on each side which pulls the wet feathers from the body of the bird. A constant stream of water washes the feathers down into a collecting pit for disposal.
Dec 17, 2011 | Computers & Internet
The drain hose pumps out too much water.
Yes it is if it is very humid and hot you know your unit is working very good. You can take the hose out farther from that spot. Set up a bird bath and let the birds enjoy a bath. just a idea.
May 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
Shower floor
A couple of layers of very heavy plastic will do the trick.
Just form up you showr pan and then cut the plastic so that it willlay nisely in the bottom of the forms.
Pour your concrete and then build you shower.
If you can afford ans they are not that expensive, you can get a complete kit at like home Depot or Lowe's.
Comes with a heavy rubber mat and a drain made to seal to the mat. These may be for a tile job, but will work for concrete also.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 06, 2009 | Kitchen Ranges
How do I repair a blown kicker subwoofer
the only way is too used some silicone glue, like what you use on bath room tiles (the clear stuff not the white concrete looking stuff) and apply to the damaged area, also you might have to replace the magnet too
Sep 27, 2009 | Kicker 05C104 Car Subwoofer
Birds Logo
43 people viewed this question
Top Birds Experts
Tom Chichester
Are you a Bird Expert? Answer questions, earn points and help others
