Question about Lexmark C530dn Laser Printer
Lexmark c530dn red light on
Lexmark c530dn
When I turn the printer on, the green light comes on then flashes, then it makes a noise and the red light comes on. It then beeps a couple of times, and the red light stays on. There is no menu available and pressing any of the menu or stop buttons only results in beeping.
Anyone know what's wrong, here? Is it dead?
    Top Expert:
  • Lexmark Master
  • 77,514 Answers
I am soory to say your printer is faulty, no use getting it fixed, the printers are very cheap to buy.
Posted on Mar 12, 2009
    Brigadier General:
  • 3,614 Answers
check the ink level, see if there was still ink on the cartrdige
  • Lexmark Master
  • 19,396 Answers
Try first leaving printer power cord for five minutes and see if this clear the error.
  • Ginko
    Ginko Mar 12, 2009
    The printer is in general error state.
    Try first leaving the printer unplugged for ten minutes or so, this can reset the error state if there is no real problem.
    Try also removing toner , inspecting the printer internally for pieces of papers or foreign objects, then putting back the toner in place.
    Try also a complete cleanup, see Clean your laser printer safely.
    If still no luck, there is need to test teh internal fuser lamp and the high voltages circuit to the drum , to find out if fuser lamp , drum or a different part must be replaced.
There is a faded blue strip on the left side of every printed page from the lexmark C530dn laser printer. I do I clean it to remove this line?
Any marks on the paper come from the drum, this could be a circumferential scratch on the drum or a void in the wiper that clears the excess toner. Whatever, you need to check the drum and possibly need to replace it.
Jan 28, 2011 | Lexmark C530dn Laser Printer
At the base of cartridge carrier,on the right-hand side is a red flashing.It flashes along with the green light on the power-on button,and the blk and colour cartridge button.Struck by lightning.lexmark...
Hello. Hope you got working already. But if you're still having the problem, unplug the power supply (the small black box behind the printer where the power cord is attached) with the other end still plugged in to a known working power outlet. Look around the black box, it should have a green LED on around the silver contacts. If not, properly secure the power cord by unplugging and plugging it back in. Otherwise, you got a defective power supply. Try not to use extensions or power strips, plug printer straight to the wall power outlet or plug it to a different known working power outlet. If the power supply is working fine, plug it back in the printer in a correct position. Properly insert it and make sure it pushed all the way in the printer. If you're still getting all blinking lights once plugged in, your printer might be damaged by the the lightning strike. If that's the case, you can call Lexmark and ask for assistance with that. Well, these are the troubleshooting steps you can do to determine where the problem is. Good luck!
Mar 20, 2010 | Lexmark C530dn Laser Printer
The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Jun 15, 2009 | Lexmark C530dn Laser Printer
Lexmark C530dn 120.03 fuser error
If you just purchased the printer today, place a call to Lexmark repair and ask for either a new printer or warranty repair.
Make sure you have your sales receipt ready, you will be asked for information about the transaction.
Apr 13, 2009 | Lexmark C530dn Laser Printer
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Lexmark C530dn Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
