Question about MTX Thunder 8302 Car Audio Amplifier
Sond gone My mtx 8202 sound in gone led is on but no sound Is the amp blown, it got pretty hot compared to the two others
  • 1 more comment
  • Daniel Champagne
    Daniel Champagne Aug 05, 2007
    went to check now that it was cooled down but it is the same!!
    It has been very hot around here this past week.
    I will check speaker and wires
    This is what I have for set up
    Audio -Compustar2wss alarm/starter security system -Kenwood KDC-Z919 Headunit -Kenwood 10 disc Cd changer -1 x MTX mid-tweeter combo in doors -1 x MTX mid-tweeter combo custom made floor kick panel each side -4 x MTX 6.5" mids rear deck -1 set clarion tweeters in rer sides -2 x MTX 15" 8000 series subswoofers in trunk encased in custome made fiberglass box that drops in spare wheel well -1 x MTX 81000 D mono amp -1 x MTX8302 2 Channel amp -1 x MTX 6152 2 channel amp -1 x 2.4 farad capacitor -0 guage wiring
    Thanks
    Dan
  • Daniel Champagne
    after doing some tests I found that I had two blown speakers on the same side.
    To veriry I took one speaker frome the goo side and hooked it up
    and it worked at both locations (floor and door) tweeters seem to be ok
    I hope it didn't hurt the amp on that side but it ran a lot cooler
    than before
    Thanks for the help
    Dan
  • Daniel Champagne
    After doing some checking I got a burn smell from the right side and it apears that I have two blown speakers.
    the tweeters seem to be ok
    I tested by taking a speaker from the floor on the other side and hooked it to both locations and it worked
    The amp also ran a lot cooler
    I hope it didn't harm that side of the amp I will find out when i get new speakers
    Thanks for all the help
    Dan
    Problem Solver:
  • 11 Answers
Sounds like an internal problem. first disconnect all spks from amp, then switch on head unit and check if amp turns on (LED ON?) then feel the heatsink, if heatsink gets terribly hot then amp has internal fault. if amp doesnt get hot then try connecting a single working speaker to each channel separately, it may occur that one channel is faulty only. amps can shut down if the speaker/s is faulty as well, check all speakers and spk wires for shorts before taking amp in for repair. cheers
Posted on Aug 05, 2007
SOURCE:
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Aug 19, 2008 | MTX Thunder 1501D Car Audio Amplifier
Amp not working need repair
You should open the amp and check if you've popped a transistor. It could also be that you've blown a relay... which really sucks lol
Dec 11, 2007 | MTX Thunder 81000D Car Audio Amplifier
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier Logo
195 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
