Question about Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook
Keyboard lock during start up phase
Just bought the computer turn it on firsttime and the keyboard is locks, with out start up properly . no password was fornulated
  • Art Ellison
    Art Ellison May 11, 2010
    What do you mean--the keyboard locks?
    Can you type?
    Have you restarted the computer?
    If it's a USB keyboard, have you plugged it into another port?
How to unlock logitech keyboard foe Ipad
follow this steps and fix it. God bless you
Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  • 2 Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  • Sponsored Links
  • 3
    Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  • 4
    Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  • 5
    Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
  • Read more: http://www.ehow.com/how_4925264_lock-keyboard.html#ixzz2aZv7Zmdg
    Jul 30, 2013 | Televison & Video
    Aquasmart lid
    Is the lid lock tang on lid broken.
    2.9 Lid Lock
    The Phase 7 Washer uses the same lid lock that is used on
    the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
    has completed, the lock will release and the lid can be
    opened. To open the lid during the cycle the
    START/PAUSE button must be pressed, the machine will
    come to a halt, and the lid locked LED will extinguish.
    If the lid is left open, the machine will be unable to lock the lid
    and the cycle will be halted. The machine will play a tune
    and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
    • If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
    lock. Note: This is the only time in which we would recommend doing this.
    • If the harness is damaged, the complete lid lock assembly will need to be replaced.
    If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
    Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
    I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
    Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
    Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
    If you found this solution helpful, please leave a positive rating!
    Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
    When i start my pc F2,F12 dont respond
    If you tap your Caps Lock key repeatedly (during the process when you are trying to click F2 and V12)... does your Caps Lock Light turn on and off? If not, your keyboard isn't recognized and may not be plugged in properly.
    Apr 15, 2011 | Dell OptiPlex GX280 PC Desktop
    The keyboard on my laptop is locked and i cant use it to search but upon startup it works and i can input the password to open it and then it locks again
    It sounds like your keyboard device driver. It may have been "updated" automatically.
    Do you have a spare USB keyboard or can you remove one from a desktop temporarily?
    Power OFF the laptop and plug in the USB keyboard. Power ON laptop.
    Use the USB keyboard, not the laptop keyboard for this procedure.
    First, does the USB keyboard work w/o locking up?
    Anyway, Go to the "Device Manager" by right-clicking "My Computer" and select "Manage".
    A list of Your computer devices will appear on the right window. Expand the +Keyboard and find the HID Keyboard Device associated to your laptop. (Pick one by checking the properties of each one to see which one may not be working)
    (( btw, HID = Human Input Device ))
    You can either "UNINSTALL" it or "UPDATE DRIVER"
    When finished, reboot, remove USB keyboard if you want to and the laptop keyboard will work just fine, or the OS will "find" it first , then start working ok.
    Follow the steps, it will work.
    Sep 17, 2009 | Acer Aspire 5100 Notebook
    Num lock key will not turn off
    Hi there.
    Hold down the Fn key and hit the Num Lock key.
    Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
    May 20, 2009 | Compaq Keyboard
    Some keys giving double letters cant enter password for windows
    Good morning! possible that some of the keys (/letters) terminal point of your keyboard were locked/stucked-up during your cleaning. I suggest to use another keyboard then check the status of the keyboard if it is working properly thru Device Manager. best regards
    May 08, 2009 | Computers & Internet
    I restarted my computer and keyboard not working
    It sounds like you might have accidentally turned on the laptop number lock. I am assuming you are seeing that characters are being typed, but the password is not accepted. If this is the case, try turning off the num lock by pressing the FN key (usually found by on the lower left by the CTRL and/or ALT keys).
    If this doesn't work, trying entering the BIOS when starting the computer (usually by pressing F2 repeatedly when you see the DELL logo). In the BIOS look for an option for the numlock and turn it off.
    Last shot - I have seen a few times where num lock is remembered when an external keyboard is used and then stays enabled on the laptop after it is disconnected. If you used a plugged in keyboard and/or use a docking station, you may want to try plugging in the keyboard again, disable NumLock (above the number pad on the right) and then shut down. Remove the external keyboard and I suspect the laptop won't have this issue.
    Hope this helps,
    Chris
    Mar 23, 2009 | Dell Inspiron 8600 Notebook
    Cant get into locked computer
    You will have to remove the keyboard and press a small button on the motherboard to reset the BIOS to factory defaults. That will wipe out any password protection you are talking about.
    G'luck
    Nov 10, 2008 | Dell Inspiron B130 Notebook
    Model no. 30222
    try the usb keyboard and see what happens
    Nov 22, 2017 | Compucessory Computers & Internet
    Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook Logo
    46 people viewed this question
    Alun Cox
