What size turntabel belt do i need for a kenwood kd21r
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: the belt that is under the plate on my kenwood
I don't have anything on that model but general advice would be to...
Try to grab the belt with something soft without sharp edges - say, a loop of yarn or ribbon. Rotate the opening in the platter over to the drive pulley (generally about the 7-8 o'clock position when viewed from the front) and using the ribbon gently stretch the belt over it. If it catches remove the ribbon and manually rotate the platter clockwise about 5-10 turns to seat it and reset any cueing mechanisms. If it's still on and tensioned replace the plate and go to the balancing act.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable and place it on a perfectly level surface.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking Force to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
Posted on May 03, 2009
Kenwood DP-R892
May be a broken belt. See if the turntable lifts out. There may be a circlip that holds it in or turn the player upside down taking care with the arm not to damage it. If the base comes off you may be able to see the belt. They are usually only the size of a skinny elastic band. If your turntable is a direct drive ( No belt) the motor may have failed.
Jun 27, 2014 | Kenwood Audio Players & Recorders
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
I need to fit the replacement turntable belt on my Kenwood stack system record player
Hi, we have all Kenwood belts in stock. What model do you have. Cheers John. Styluscity@gmail.com
Aug 09, 2011 | Kenwood Audio Players & Recorders
Need 2 know wht size speakers are needed in my truck (doors,Dash)
You can go to crutchfield.com to input your vehicles specific information and they will tell you what size speakers you need for different locations.
Dec 14, 2009 | 1992 GMC Suburban
I need to put the belt back on th KD 48F turntable
its likely that the belt has stretched and therefore will keep happening as its no longer http://www.needledoctor.com/Online-Store/Turntable the right size? go to this site for a replacement?
Aug 21, 2009 | Kenwood Audio Players & Recorders
The belt that is under the plate on my kenwood kd21r if off how does it go on can you send a diagram and to balance the wts how do I know the proper no's?
May 03, 2009 | Kenwood Audio Players & Recorders
Turntable won't spin
you need to open the under neth there is a belt that turns the turntabel one it could be the belt broken 2 it is slipping cheers peter
Apr 05, 2009 | Philco (R) Classic Turntable CD Shelf...
Door to load cd's wont open or close without help.
Hi...
I use a place called
www.studiosoundelectronics.com
or
matelectronics.com
Studiosound will even tell you how to measure your belt if you need to
Godspeed,
Scott
Dec 16, 2008 | Yamaha CDC-845 5-Disc CD Changer
Looking for source to replace broken cassette drive belts
find something else with the same size belts there just belts don't have to be same kind i'd go a lil smaller then the old ones
Mar 27, 2008 | Audio Players & Recorders
90 people viewed this question
 Grubhead
Grubhead
