No power or lights
Our Whirpool duet ht has no power. It quit while washing a load. I tried unplugging and plugging back in. What now?
    President:
  • Washing Mach... Master
  • 662 Answers
Http://www.youtube.com/watch?v=Sij3UOZthiY
Maybe......... this cud help
Posted on Apr 24, 2013
bbtoast
  • 319 Answers
SOURCE: Whilpool washing machine model "Duet ht" fornot load
Press and hold the End Of Cycle Signal button
for 3 seconds to turn this feature off.
When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
Good Luck, hope this FIXED YA
Posted on Jan 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Posted on Mar 05, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
SOURCE: washing machine turns off after pushing start button
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force. Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Posted on Nov 21, 2011
MY WHIRLPOOL FRONT LOADER WASHER JUST QUIT WORKING. IT HAS LOST ALL POWER. THE DOOR WILL NOT EVEN OPEN. PLEASE HELP?
I've worked on similar models with all manner of problems. Try unplugging the machine from the electrical outlet for about 30 seconds then, plug it back in. This will "re-boot" the control board. If it doesn't work, I'd say the control board is bad.
May 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirpool duet ht washer that doesn't seem t want t spin on high. Trying to wash one coat by itself and it is soaking wet. Have tried drain/spin mode only but all it wants to do is rotate clockwise...
If you only have one coat in there, that is a problem. It will notice the unbalanced load and shut the spin down and try to redistribute the load. Try adding a few wet towels to offset the weight of the coat. This will likely take care of the problem.
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the code to open a Whirpool washer machine Duet HT
Switch on the washer. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet HT and the control is locked. how do i unlock thanks
Mine is doing this all the time, I finally got tired of pulling the washer out to unplug it so I plugged the washer into an extension cord that's easily accessable, so unplug it for at least 30 mins before you plug it back in reset to drain and spin cycle for 12 mins and your load should finish ok. These washer and dryers are beginning to be a pain in my....neck.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirpool duet. the door is on lock mode and i can not cancel. what can i do
This has happened to me...unplug and plug back in. If possible, start the machine on a normal wash cycle. It will start, then the door will unlock at the 'add a garment' portion of the cycle (usually a few seconds into it). Hope this works!
Jan 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you turn off the control lock?
Directions are under rightmost button. Please contact me if you need further help or leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
TROUBLESHOOTING
Ok here is what you do.
Unplug it for at least an hour. That means pul the plug out of the socket.
If it does not work I would advice to use the warranty of the machine. Call the store and let them replace it.
If you do not have waranty come back to me
Apr 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
