Question about Refrigerators
Sears Kenmore Refrigerador
Water not coming out from refrigerator
    Scholar:
  • 145 Answers
If you mean water from defrosting then most probably its blocked pipe. You can disconnect the pipe by pulling it out from backside and clean it. But then question also arise where the water is going? is your freezer compartment flooded after defrosting?
Posted on Apr 24, 2013
22yooper
  • 828 Answers
SOURCE: My mom has a Galaxy
It will more than likely be the right part because Galaxy is made by Whirlpool who also makes the Kenmore Line for Sears.
Posted on Jun 20, 2008
SOURCE: kenmore refrigerator
my refrigerator is not cooling.
Posted on Oct 04, 2008
davidpsr
  • 222 Answers
SOURCE: sears kenmore refrigerator . refrigerator doesnt
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Posted on Aug 29, 2009
  • 401 Answers
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Posted on Jan 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: ice and water on the bottom shelf of my sears
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Posted on Jan 18, 2011
Walter with bad semelhante in the back of refrigerador
Cooling is proper. If cooling is proper then drain line to be cleaned.
Dec 15, 2013 | Sharp Sj-K70mk2-Sl Top Mount Refrigerator...
Not making ice but water coming from dispenser? Kenmore side by side refrigerator
your inlet valve has two different valves. one is broken so you have too buy a new valve. sears is a good choice if you don't have a friend in the profession, or you could get the part less expensive
Aug 11, 2010 | Kenmore 58522 Side by Side Refrigerator
I have a kenmore modle 52559100
I am working through Sears Commercial Parts Direct and I cannot find that correct model number. Double check. Filters do not suddenly stop flow. Water control valves yes and when you have an ice maker the water valve has two sides. Water control valves are located most times on rear of refrigerator and near floor where the house hold water enters the refrigerator. Sometimes hiding behind a paper cover. Your number really looks good to me and I was surprised that it will not work. Double check and correct that number and I will be able to assist you better. In a way I wish Sears would not change the numbers. The 525 in the number is who made your model and 525 does not come up. Sea Breeze
Mar 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not cooling the refrigerador side
hello mam
please check the temperature settings of the refrigerator this should be in normal mode.and check the blower of the refrigerator if you find any abnormal please call the engineer.
Sep 25, 2009 | Fisher and Paykel E522BRXFD Stainless...
I have a Kenmore side by side Model# 59422. There
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE SIDE BY SIDE REFRIGERATOR. QUESTION REF WATER FILTER
need to replace the filter every six months and yes you can get them at Sears but not Walmart
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite Trio 795
check the damper controller at the center of the fridge. this regulates the air that is coming from the freezer dependent on the signal from the thermistor of the fridge compartment. that is the other thing to check. check it for rresistance and it should change as you change the temperature of the sensor.
i hope i was able to help;;
May 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Replacing actator-water on kenmore side by side .
the water tray probably just pulls out and there's screws near the base that comes out. up underneath there should be some screws to take out. thhen the unit comes down and out the front. wires and a hose will be coming out with it.
Sep 19, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
