Question about Ricoh Office Equipment & Supplies
Getting a dark strip on all copies on one side
Can you help?
Fuser, drum, optics, development.....hope that helps.....maybe next time offer a model #
Posted on Mar 13, 2009
  • Anonymous Mar 13, 2009
    Inappropriate?? It's one of those 4 things. What am I a psychic?
When I copy using the auto feed, I get a line across my copies. The line can fade or be dark but has been present for a few months. Copies that are hand placed do not have the line. What can I do?
There is usually a little strip of glass to the left of the main glass bed where you would place paper by hand. This little strip is what the feeder passes the paper over to scan it while the scan head stays in place underneath it. Most likely there is some fuzz or dirt on this strip of glass or on the feeder where the paper passes.
Oct 18, 2010 | Ricoh Office Equipment & Supplies
When i make copies a line appears on the right side of the copy. This problem does not occur when i scan to copy only when the document runs through the feeder
Clean the document feeder scanner glass. This is the much smaller strip of glass that is to the right of the large main glass. This strip of glass is used ONLY when using the feeder. So if you are getting a dark line when using the automatic feeder but not when laying a document on the glass then just clean the strip glass. 100% sure this is your problem. You may need to clean it several times as I have seen stuff get stuck to this glass.
Good Luck and Thank You for using Fixya.
Jun 02, 2010 | Xerox WorkCentre XD120f Copier
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
No matter how I clean it according to the manual I cannot get the dark line to disappear on our fax machine copies
the dark lines are caused by these things so check.
the thin strip of lamp dirty, or a light is bad
the drum has a dark toner ring around it, change
the fuser is dirty or is bad
Sep 17, 2008 | Sharp Office Equipment & Supplies
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
Dark strip
LIFT THE COVER UP AND CHECK FOR A SOMETHING ON THE NARROW GLASS IN FRONT OF WHERE THE FLAT BED SCANNER SCANS .
COULD BE WHITEOUT OR GREASE MARKER OR EVEN A DIRTY PEACE OF PAPER
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
