Question about Technics SL-BD20D Turntable
Why douen't my technics turntable spin?
When I move the arm I can hear something running but the table doesn't spin.
    Master:
  • 434 Answers
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
Posted on May 30, 2014
djproaudio
  • 515 Answers
SOURCE: Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
Posted on Sep 23, 2007
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
SOURCE: technics turn table
under the tone arm next to the lever ther is a sort of plastic bar which lifts the tone arm when lever is up right, look along that bar and there is a screw which you turn as you would to tighten anything.you will see the bar move down,try again and if you still have the same problem repeat the process till done......
Posted on Jul 07, 2008
djredskyy
  • 670 Answers
SOURCE: serato does not recognise my
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
Posted on May 27, 2011
Deneenie
  • 73 Answers
SOURCE: I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Posted on Feb 22, 2012
Turntable arm not moving across record?
Try, without any record on the table, if you can move the are, to the centre of the table. If you feel anything that is holding the arm, try to find out what it could be. Never use force. Also look inside if you can't find a clear obstruction on the top of the table. If you should find anything, don't bent, or don't break anything. Let a technical skilled person look why the obstruction is there and where the "thing" should be so the aren can move free. Perhaps you ned the obstruction for something only a few centimetres to the left or the right.
Jun 26, 2014 | JVC Audio Players & Recorders
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Feb 20, 2012 | Technics Audio Players & Recorders
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
I have a Technics SL-QL1 direct drive turntable that works perfectly for about 5 seconds, then it suddenly repeats itself over and over... the record never advances beyond that point. It happens with any...
I don't think it's the direct drive as that just makes the platter spin around. Since the stylus sits in a record which moves it forward, if it gets stuck then it's going to be something to do with the arm of the record player that can't move beyond that point. Check around the piviot of the arm for problems and look at the anti-skating control. If you can move the platter by hand that will prove it's not the drive if the stylus gets stuck.
May 25, 2011 | Technics Audio Players & Recorders
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Hoe do operate the turn table
Lift the arm off the stand and manually move it to the center of the player. You should hear a click and the turntable will begin spinning. To turn it off move the arm to the outside until you hear a click.
Nov 13, 2007 | Philco (R) 841.205 CD Shelf System
Technics SL-BD20D Turntable Logo
142 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
