Question about Lexmark C734DN Laser Printer
201.08 pj every time
Hitachi pj tx 100..put in after maeket bulb...woeked great for 300 hrs then went very dark....put another bulb in no difference ??
you need a new Original lamp
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 17, 2014 | Hitachi projector replacement lamps pj tx...
Replace inside bulb of projector lamp for Hitachi
check the site below
http://www.aboutprojectors.com/pdf/hitachi-pj-tx200-manual.pdf
thats the manual
Jan 09, 2011 | Hitachi Cine Master PJ-TX200 Multimedia...
Panasonic PT-AE4000 Shuts off
This is a serious issue and It seems as though you have got a defective peice. Either the PJ was damaged when in transit or it was a faulty piece. The PJ could have a defective lamp because if it is trying to trip off on loading , then the chances are that the Lamp is taking intoo much current and tripping off the circuit. Since your PJ is brand new, if it is under warranty , you must take the privilege of free replacement of the part, than to try any repairs. What could be done is to check again for power connections faulty voltage. If not since the trouble shooting was ably done there is not much to check than to take this decision. You must ask them to give you extended warranty and claim for damages if they seems unhelpful. Hope you decide with my advice. Good day
Jul 26, 2010 | Panasonic Ptae4000e Ptae4000u 1080p Hd...
Horizontal colored lines screenplay 4805
First: Check your connections. Some times people can have the cables connected the wrong way in the pj which makes the screen either all red or distored looking, etc.
If that doesn't work..
Then any thing that has horizontal or color lines, dots, or zig zags on the pj means something wrong with the mother board. This is something that you can not typically do on your own. The best way is to have an authorized in focus dealer work on it, even if its no longer under warranty you can find out great locations through their website or themselves for the people whom are used to fixing pj's otherwise you might run into other problem if some one is not experienced in pj work.
I've worked for a competitor to this brand in the past and that was always a huge sign that something internal was going on if it wasn't a connection error. 9 times out of 10 it was an internal error. I did have some one whom hooked up his component cables wrong which created a red/green image. Once he fixed that it was okay after that.
Let me know how things go. I wish you luck. Some times its hard to trouble shoot all the way through with out being there. Let me know how things work out.
Sep 09, 2008 | InFocus ScreenPlay 4805 Multimedia...
Hitachi PJ-TX10 alligment
i have one of these projectors found on setting it up that the projector must be square on with the screen, the pjtx10 doesn't have ant "wedge type" setting like sony does. if this doesn't fix problem there is some thing not aligned in the lense
Mar 04, 2008 | Hitachi PJ-TX10 Multimedia Projector
Epson powerlite 7700p video problems
could be, colour change is typical of a pj lamp expiring.
check first the connection lead between pc and pj
to make sure pj is seeing all signal pins on sub d lead.
check pj with video sig input, if thisis ok it's not the lamp failing
Feb 20, 2008 | Office Equipment & Supplies
Lexmark C734DN Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
