Question about CYBERPOWER SYSTEMS USA CyberPower 7050SG - Surge suppressor - AC 125 V - 7 output connectors
CyberPower 70505g I cannot get the other outlets to stay on in the "green" slave area. I have the Master plugged to an adding machine that is constantly on, but my laptop charger will go off after 5 min if it is plugged into a green outlet. My other outlets are being used by the pc and devices at my desk. Can you help
What SATA cables do I need to hook upDevice? Have factory installed into my CyberPower Desk top a LG Multi BlueRay/DVD/CD
SATA devices do not have jumpers to configure as a slave/master.
You connect each SATA device to separate SATA connector on the motherboard.
Nov 20, 2012 | LG GH24NS90 24x DVD RW DL SATA Drive Black
How to hook up my Cyberpower to HP PC
Plug CyberPower to wall then plug PC to open outlet.You can connect monitor and other devices as well. The network cord can also be looped into unit. One in. One Out. Make sure power on strip is turned to use PC and other nodes on strip.
Aug 28, 2012 | CyberPower 625AVR (cps625avr-sc) UPS...
How connect slave drive dell computer?
I assume you are trying to add a slave drive to a Dell DESKTOP? If so, is it an IDE drive (standard hard drive). To that you will find a jumper plug, usually beside where the cable plugs in but sometimes on the opposite side. The jumper options are usually listed on the drive but what you will need to do is place the jumper plug in the slave slot. You will also need to move the jumper plug on the original hard drive to the master slot. That always seems to work the best for me. However, you can try adding plugging the slave drive into the next open slot on the IDE cable, which is already plugged into the original hard drive. If you get lucky it may automatically recognize the new drive as the slave. You may need to setup/configure the BIOS to set the master and slave drives. To check BIOS setting, hold F2 or F10 when you turn on/boot the PC.
Apr 20, 2012 | Dell Computers & Internet
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
Why does the 4 outlets (surge only) of my cyberpower 685avr work while the 4 outlets with battery doesn't?
The battery only works when it isn't plugged into the wall. That's what a battery backup is for,so when the power goes out, the battery kicks in.
May 08, 2011 | CyberPower Intelligent AVRLCD...
I have an emachine T5062 desktop. A friend of mine took an old hard drive out of another machine and added it to this machine. Now the desk top won't boot to windows - it keeps rebooting and sounds like...
You need to set the second hard drive up as the "SLAVE". There is a small jumper on the end of the hard drive where the power cable and data cable plug in. There should be a diagram showing where the jumper is placed to make it the SLAVE.
As far as figuring out which is which (MASTER .vs SLAVE), the MASTER is the last drive on the cable.
I hope this makes sense...
Good Luck.
Jan 27, 2011 | E-Machines eMachines Desktop PC
I have an acer v229w and would like it to turn off when i power of my compu??
Just Google 'Green outlet strip power saver'
It is an outlet that you plug the PC into the 'Master' outlet, and you plug in your monitor, printer into the 'SLAVE' outlet. The Master outlet will sense the current draw (there is sensitivity adjustment) by the PC then it will turn on the Slave outlets, when PC is turned off, the slave will turn off also.
Apr 22, 2010 | Acer AL1916W 19" LCD Monitor
Turn off monitor
One way to do it is to use the switched outlet on the back of the PC to turn on and off the monitor, but most new PC's do not have this switched outlet any more.
Another way is to use these green outlet strip, the PC is attached to the master outlet, the monitor and anything else will be pluging into the slave outlets, When the master outlet senses the current draw (sensitivity is adjustable) from the PC, the slave outlets will be turn on.
Example: http://www.provantage.com/siig-ce-sp0112-s1~7SII20CL.htm
Apr 01, 2010 | Optiquest 17" DPT Q71-5 Monitor
CYBERPOWER SYSTEMS USA CyberPower 7050SG - Surge suppressor - AC 125 V - 7 output connectors Logo
22 people viewed this question
Top CYBERPOWER SYSTEMS USA Computers & Internet Experts
David Payne
David Payne
Are you a CYBERPOWER SYSTEMS USA Computer and Internet Expert? Answer questions, earn points and help others
